New User use PineBookPro default OS Manjaro
Hi to all.
Just don't use the graphical program to  install or update the system, it does not work.
For exemple I tried to installl chromium but I got errors of dependensies.
With the command line I was able to install chromium with no problem.
The commands:
Update OS: sudo pacman -sYu
Install a program:
sudo pacman -S chromium   (and it works)
Now I love Manjaro.
  default login & password, Pinebook Pro? kiloseven 1 1,636 12-11-2025, 12:11 AM
Last Post: kiloseven
  Hello All! New user - 2 basic Quartz64 questions oldschool 2 5,106 12-14-2023, 12:06 AM
Last Post: oldschool
  Can I use the pinetime as a blind user pranav 1 4,366 06-22-2022, 01:07 PM
Last Post: zer0sig
  Invalid package error in Manjaro-ARM? Easy fix 98cwitr 0 3,286 05-23-2022, 08:49 AM
Last Post: 98cwitr
  First time user experiencing weird keyboard issues kendew 5 10,969 06-19-2021, 08:14 AM
Last Post: rotwang
  Java on Manjaro ARM Pinebook Pro gulagpyromaniac 3 7,763 05-25-2021, 11:05 AM
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 5,594 02-02-2021, 12:13 AM
Last Post: PineSupporter
  Email addresses in Claws for Manjaro-Arm James Good 6 12,736 08-30-2020, 07:52 PM
Last Post: bcnaz
  brand new manjaro PBP - pacman PGP import failure shindagger 0 3,553 06-18-2020, 07:19 AM
Last Post: shindagger
  A newest user in Pine64 Aliko 1 6,599 04-19-2020, 10:33 PM
