Rock 64 failure / kernel panic
Hi, I am using Rock64 computers for a product and a few of them are failing in the field.  The symptom is that the computers lock up with a kernel panic (kernel paging request fail) and then do nothing until a power reset is performed.  It seems that the problem is memory related as we have started running memory tests on them and some of them fail the memory tests in as little as 5 minutes or less.  We have tried it with the 1 GB Rock64’s and also with the 2GB Rock64’s and they all exhibit the same failure issues.
Has anyone come across these issues? And is there any workaround or fix for it??
(06-30-2022, 09:59 AM)n0021913 Wrote: Hi, I am using Rock64 computers for a product and a few of them are failing in the field.  The symptom is that the computers lock up with a kernel panic (kernel paging request fail) and then do nothing until a power reset is performed.  It seems that the problem is memory related as we have started running memory tests on them and some of them fail the memory tests in as little as 5 minutes or less.  We have tried it with the 1 GB Rock64’s and also with the 2GB Rock64’s and they all exhibit the same failure issues.
What OS is running on them.
I've been running armbian on mine without issue, but you might end up having to adjust the RAM frequency on problem boards.
  Rock64 kernel panics clay 15 23,739 10-17-2021, 06:30 PM
Last Post: Rocklobster
  Rock 64 seem like a dead end munocat 3 8,340 03-21-2019, 10:13 PM
Last Post: thewonderer
  Rock 64 a failure..very disappointed arxaios 5 11,358 11-02-2018, 07:29 AM
Last Post: Trash_Can_Man
  [Issue] All Rock leds are blinking Chispolas 6 13,963 04-18-2018, 09:12 PM
Last Post: pfeerick
  Rock64 kernel compilation - configs acrobatbob 0 3,467 04-06-2018, 02:55 AM
Last Post: acrobatbob
  [Warning: root device does not exist] Can not install generic kernel on ROCK 64? pine3228 0 4,003 03-16-2018, 05:40 PM
Last Post: pine3228
  [Repaired] [Progressed] [Successful] How to play Minecraft with ROCK 64 pine3228 9 19,438 03-11-2018, 07:46 AM
Last Post: pine3228
  booting a kernel over tftp hibernick 0 3,140 03-08-2018, 10:37 AM
Last Post: hibernick
Sad Rock 64 No video borisacomputers 4 9,426 03-03-2018, 03:11 PM
Last Post: borisacomputers
  Error when building kernel - realtek krystian 1 4,042 02-25-2018, 03:58 AM
Last Post: krystian
