New user/phone here - initial update issues
Question
Hi!
New to the pinephone and this forum. I just got my new pinephone in the mail today and am running into some issues after trying to install initial updates.
Here's what happened:
  1. Installed initial ~1Gb software updates through Discover, it rebooted and installed them fine
  2. Discover said I had 600+ additional updates to install, but the size was 0 bytes
  3. Tried to install those multiple times. It rebooted, said it was installing updates but every time I re-opened Discover it said those 600+ 0 byte updates still needed to be installed
  4. Decided to update through cli instead and ran sudo pacman -Syu
  5. Updates installed, rebooted, but every time it restarts Discovery says that there was a "failed offline update" for the hwdata package. Offers the open discover or repair system buttons. The repair system button does nothing, and when I try to update through both discover and cli it says I'm "all up to date"
  6. However, the on-screen keyboard is now broken (it hangs for a few seconds when I type something, then closes, and then reopens but doesn't type anything)
Any advice on what I should do now?
Should I just re-flash this and start again, or is there some cli repair system package command I can run?
For the record, at some point I recall running
sudo rm /var/lib/pacman/db.lck
Due to an issue related to this
I've used KDE a lot but only on Debian-based systems so I'm a little fresh at this, thanks!
[Image: rC4sOb.jpg]
As PinePhone is in continuous development, it is always a good idea to make a fresh start by flashing the latest "factory" or beta image.
My experience with Manjaro PlaMo: https://forum.pine64.org/showthread.php?tid=15300
(06-29-2022, 03:57 AM)acrux Wrote: As PinePhone is in continuous development, it is always a good idea to make a fresh start by flashing the latest "factory" or beta image.
That's very helpful thank you!
  How-To: Remote Control Your Phone from Desktop via VNC biketool 16 17,409 10-16-2025, 06:55 AM
  Jami on the Pine phone ? bcnaz 8 16,803 06-09-2025, 04:17 PM
Last Post: j_s
  Article: NuttX RTOS for PinePhone: Feature Phone UI in LVGL, Zig and WebAssembly lupyuen 64 68,049 09-09-2023, 09:49 AM
Last Post: WhiteHexagon
  Article: NuttX RTOS for PinePhone: Phone Calls and Text Messages lupyuen 2 4,753 05-03-2023, 05:03 PM
Last Post: lupyuen
  [Stupid Question] Where is the phone camera software?! newusername 5 8,325 10-10-2022, 03:58 AM
Last Post: newusername
  Issues with PinePhone Pro Glenn 1 3,385 07-28-2022, 11:56 AM
Last Post: Airdale
  Which apps can I run on this phone? poppyhodler 2 5,956 06-07-2022, 12:18 PM
Last Post: jenniferjohn12
  Phone Operation which SW Realease (mute funtion)? scrwbigtek 0 2,373 05-25-2022, 07:35 AM
Last Post: scrwbigtek
  First time pine phone user Matt73 3 6,294 03-10-2022, 02:04 AM
Last Post: Matt73
  Phone Shell Nextcloud message notifications: turn them off? lsitongia 0 2,653 09-28-2021, 11:04 AM
Last Post: lsitongia
