Pinephone Pro LCD and Touchscreen
Hi Everyone,
I hope you are doing well! Yesterday while out for a hike, I managed to drop my pinephone pro which has led to the screen looking like a spider's web. The screen doesn't turn on so I assume I managed to break both the touchscreen and the LCD.
Looking at the wiki it doesn't appear the OG Pinephone and the Pro version use the same screen (I may have ready it wrong), I am curious if anyone knows when the LCD might be available to order since it appears only the OG Pinephone LCD is available on the store.
I appreciate any help in this.
Regards,
Gj
(05-15-2022, 11:12 AM)Hobgoblin Wrote: Hi Everyone,
You are correct, the two LCD’s are not the same.
You could email Pine64, and ask them if they have a spare one you could buy - and/or when they will be available.
Thank you very much for this. I followed your advice and was told that due to the phone being so new, the screens should be hitting the store next month. Just a waiting game now Smile
Regards,
Gj
I would recommend to open a ticket under support.pine64.org, the support should have some spare parts available even without the part being sold in the store yet.
Regards,
Gj
Thanks for the advice, that is what I ended up doing and they said June. I appreciate the suggestion. Really looking forward to getting the Pro fixed Smile
If I understand it correctly, to remove the frame to replace the screen one needs to remove the "warranty" sticker.
Is there any way to have the replacement done by Pine64?
(04-26-2023, 01:14 PM)saper Wrote: If I understand it correctly, to remove the frame to replace the screen one needs to remove the "warranty" sticker.
If you don't feel comfortable with doing a screen repair you can ask in the community chat and send it to a community member to do the repair. Shouldn't be too hard, you can check YouTube for how to do it, it's basically the same for the regular PinePhone.
Smile
Just in case you are uncomfortable with screen replacement i recently replaced my screen and made a video tutorial on in (sort of  Smile ) so if you want, and in urge, i just need to edit that and post on youtube, if still relevant.
https://www.youtube.com/watch?v=HOeWQ9So4ak
Exclamation Pinephone pro stuck while booting Supervisor 3 2,041 10-07-2025, 02:46 PM
Last Post: Supervisor
Question Are there plannes to create a new and more powerfull PinePhone Pro? Nima0908 5 11,925 08-18-2025, 04:12 AM
  Pinephone pro packet injection for internal wifi chipset covar 3 3,607 07-02-2025, 02:03 PM
  RTKLIB PinePhone Pro GPS jlaba 1 1,404 05-02-2025, 12:43 AM
  PinePhone Pro disable Volume Buttons when malfunctioning ArchBene 0 1,025 03-12-2025, 05:51 PM
Last Post: ArchBene
  PinePhone Pro Explorer's edition Qualcomm modem recovery shifras 11 9,135 02-28-2025, 07:03 AM
Last Post: tensa1000
  PinePhone Pro EDL boot by shorting contacts ozkenlc 3 4,170 09-18-2024, 04:59 AM
  PinePhone's LED is blinking, but doesn't start zvavybir 0 1,330 09-06-2024, 02:39 AM
Last Post: zvavybir
  Pinephone pro shuts down immediately after login covar 4 4,006 07-03-2024, 10:59 AM
Last Post: covar
Thumbs Up Pinephone Pro + Keyboard for sale Jimmy88 2 3,323 04-22-2024, 08:38 PM
Last Post: AegisWages
