Keyboard Power Issues
(04-23-2022, 02:05 PM)fxc Wrote:
(04-23-2022, 03:42 AM)dgiffin Wrote:
(03-29-2022, 03:11 AM)Merc Wrote:
(03-28-2022, 02:54 PM)dgiffin Wrote: My keyboard case used to work with my PP but not my PPPro, now it doesn’t work with either ?
It seems like everyone is having problems with the keyboard. It's hard to tell if it's the hardware that's bugged or the software or what's really going on. Our keyboards might be broken or maybe there's something wrong with the software or the pogo pins. It's anyone's guess as to what's actually going on.
Do the pogo pins on your PinePhone Pro look the same as mine?
My PPP pogo pins look Ok to me - the keyboard is recognised now (keys working) but the charging is still a mystery - side switch seems to do nothing, keyboard battery seems to charge but doesn't seem to power the phone - not sure what's going on to be honest.
The side button turns on and off the charging between keyboard and PinePhone. If the charging does not work but the keys do you will likely have to add shims to the pogo pins, as they are not making proper contact, see https://wiki.pine64.org/wiki/PinePhone_(...er_contact
Ah, I'm not very good with things like that, more likely to break something :-(
For clarification, the shim is a piece of paper or cardboard behind a plastic part, not some difficult procedure.
Just lift the connection tab with a dental pick, small flat-head screwdriver or your fingernail and insert a folded piece of standard paper (cut to size).
PinePhone, Pinebook Pro & PineTab2 owner.
(04-26-2022, 07:38 AM)dachalife Wrote: Just lift the connection tab with a dental pick, small flat-head screwdriver or your fingernail and insert a folded piece of standard paper (cut to size).
Ok, will give it a try!
  Keyboard availability? KaylaMarie81 9 6,574 08-04-2025, 08:37 PM
Last Post: Peter Gamma
  Keyboard not working PPP is support broken atm? joshndroid 13 16,556 02-24-2024, 01:59 PM
Last Post: mburns
  The XIT bluetooth folding keyboard can work with the Pinephone Pro mburns 0 2,495 11-09-2023, 10:57 AM
Last Post: mburns
  Fixing the PinePhone Keyboard for the Linux Console mburns 0 2,733 09-02-2023, 07:48 AM
Last Post: mburns
  Keyboard charges, won't type - ERROR: I2C_RDWR failed: No such device or address jovval 0 2,814 07-10-2023, 08:11 AM
Last Post: jovval
  Power pass through USB-C dock that works? (HDMI out and charges phone) jcun4128 8 13,084 01-15-2023, 08:41 PM
Last Post: fox95
  Checking Keyboard Charging Status dgiffin 0 4,268 04-23-2022, 03:40 AM
Last Post: dgiffin
  Use keyboard case as virtual mouse EwigeBlumenkraft 1 5,878 03-24-2022, 05:22 AM
Last Post: magdesign
  Hardware keyboard top row keycodes problem cyrelk 2 6,376 03-03-2022, 03:01 AM
Last Post: cyrelk
  Keyboard case issues dgiffin 10 19,059 03-03-2022, 12:56 AM
Last Post: tcoulon
