Disable mobile data auto-enable on boot
I've followed the instructions at the wiki on setting up mobile data, and it works fine, except that it really kills the battery. Every time the phone boots it auto-enables any connections it can, which means to prevent the phone from automatically overheating and dying after a few hours in my pocket I need to remember to manually turn data off.
Is there a way to configure the modem connection with nmcli to keep it from turning on automatically, or should I just have a script run a few minutes after boot to turn it off?
The second option seems kinda hacky to me so I'd rather avoid it, but I'm using sxmo so I might as well embrace the way of the bash scripts...
I'd like to know the answer to this as well. It is disheartening to see that no one has come forward to answer or reply.
@ 64_Tesseract : what did you finally do to resolve this issue?
I too would like to find an answer to mobile data being auto-enabled at boot, surprised no one has come forward yet. Can you tell me what you eventually came up with?
(08-10-2022, 02:36 PM)keithosterag Wrote: I too would like to find an answer to mobile data being auto-enabled at boot, surprised no one has come forward yet. Can you tell me what you eventually came up with?
Turning it off manually lol
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 3 7,576 11-18-2024, 02:23 AM
Last Post: linmob
  Gnome mobile user641 1 3,882 01-06-2024, 11:06 AM
Last Post: Uturn
  NextCloud Gnome Mobile Uturn 4 7,126 12-03-2023, 07:54 AM
Last Post: Uturn
  Fresh install pmos+phosh does not boot user641 1 3,724 10-08-2023, 04:04 AM
Last Post: user641
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 5,784 10-03-2023, 06:32 PM
Question Always Use Mobile Data DingDangDoong 4 6,655 04-20-2023, 06:18 AM
Last Post: DingDangDoong
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & No MMS X0X0X0X0X0 1 4,214 11-07-2022, 10:34 PM
Last Post: X0X0X0X0X0
  No Application Data PMOS 21.12.1 Captain1ndustry 4 8,754 08-12-2022, 07:42 AM
Last Post: Gon
  wwan0 (cellular data) ip configuration is POINTTOPOINT not BROADCAST dc2daylight 0 2,664 04-07-2022, 07:16 PM
Last Post: dc2daylight
  Calls don't work on Softbank. Cellular data & SMS work. yasmi 1 3,776 03-24-2022, 04:10 AM
Last Post: yasmi
