Slash TV Android for RockPro64
(03-28-2022, 01:19 AM)Wizzard Wrote: I was able to uncompress it, maybe I used Windows or some other trick.
When you say you managed to "uncompress it" which of those five files on Google Drive did you use. They all look a little weird to me and definitely don't uncompress into a usable img file in either Linux or Windows.
You need to download them all, it is multi-volume archive.
(04-22-2022, 04:55 AM)Wizzard Wrote: You need to download them all, it is multi-volume archive.
Yes I’ve downloaded all four images. What process did you use to create one single bootable image from the four downloaded files. Maybe you could post a simple set of instructions for others to follow too.
  Android images for RockPro64 BitAnnihilator 5 18,103 06-04-2024, 11:05 PM
  Difficulty installing Android on Rockpro64 spammycheese 0 5,788 02-17-2023, 05:31 AM
Last Post: spammycheese
  Using Android and the Playstore grobbs 0 6,125 06-04-2022, 12:18 AM
Last Post: grobbs
  DRM support in Android Wizzard 2 7,641 02-03-2022, 09:16 PM
Last Post: Johnmo89
  Install Playstore on Android 8.1.0 Domo 14 46,082 04-16-2021, 02:13 AM
Last Post: Wizzard
  Install Playstore on Android 7.1.2 Domo 6 25,447 04-16-2021, 02:10 AM
Last Post: Wizzard
  Kodi crashing in Android 9 Wizzard 2 7,740 04-16-2021, 02:03 AM
Last Post: Wizzard
  Install Playstore on Android 9 image ddimension 18 50,156 02-13-2021, 12:52 AM
Last Post: chisteven
  RockPro64 line out/headphones in Android 9 Wizzard 0 6,127 11-20-2020, 04:15 AM
Last Post: Wizzard
  Android 9 drivers Firesped 1 7,022 11-19-2020, 12:39 PM
Last Post: Wizzard
