User login change
Thanks for the info. gdm3 works fine and the work a round works to.
(04-04-2022, 12:49 PM)onubatux Wrote: I got it using gdm3
First you register a new user from the console with the command: (change diego for your name)
sudo adduser diego
Install gdm3 this is the process
first update the repositories using:
sudo apt update
then we install gdm3
sudo apt install gdm3
It is not necessary to restart, and do not despair that it takes a little while for the gdm3 screen to appear, but it appears as you can see in the images above.
when you get the gdm3 screen you will see the two users:
the touch screen works normally. You select the new user (if not, it's not funny)
important in bottom gear select phosh environment
and to make the keyboard appear you drag from bottom to top.
and enjoy the new user.
I have found a small bug in the use of gdm3. When you start the phone, you barely have time to see the gdm3 screen.
The solution I have found right now is the following:
You enter with the default user, the first on your list. In my case it is mobian as you can see in the first photo that I have passed.
When you are with that user you go to a command console and use the following command:
sudo systemctl restart gdm3
and it is fixed until the next reboot of the phone.
You can exit and change users as many times as you want, gdm3 will only fail when starting the phone. but we already have a solution.
Enjoy whoever wants to use it.
Can you kindly elaborate how do you switch the users? Say from mobian (default user) to mobian2 and then back to mobian?
If I make both users admin (sudoers) I can with both users restart the gdm (sudo systemctl restart gdm3) but that is very cumbersome.
I tried opening up terminal and do CTL+ALT+F6 and CTL+ALT+F12 to switch between desktops but that didn't work...
Thank you
  Auto start application on Phosh login Zebulon Walton 8 13,395 10-14-2023, 06:29 AM
Last Post: alaraajavamma
Exclamation Impossible to login since the latest update anonymous 12 17,300 02-26-2023, 01:01 PM
Last Post: anonymous
  Change GUI from Phost to Gnome (or anything else) johnpine 0 2,316 05-27-2022, 06:52 AM
Last Post: johnpine
  How to do automatic login or shorten the login number amosbatto 0 2,695 12-08-2021, 09:29 PM
Last Post: amosbatto
  GDM3 Receiving call on login screen d-.-b 4 8,615 10-07-2021, 06:59 PM
Last Post: d-.-b
  Change default program for a file type 3x5co 1 3,935 09-01-2021, 05:26 PM
  Change locking of Ctrl modifier? vandys 1 3,631 05-08-2021, 02:46 AM
Last Post: MtnSk8
  Debian / mobian Pine64 - User Manual? Harry27 1 5,933 03-03-2021, 04:50 PM
Last Post: LibrePhoneUser
  How to change the minimum password length when changing from default passwords arturo2bodegas 3 9,230 07-18-2020, 01:51 PM
Last Post: arturo2bodegas
  power management change? pjsf 1 5,965 06-05-2020, 05:16 PM
Last Post: a-wai
