wget not working?
I am a 90% n00b when it comes to Linux.
I got my Pine64, I got a non-counterfeit SD card, and put the Debian install on it.
What I am trying to do now is get JRiver Media Center for ARM installed using these instructions:
http://yabb.jriver.com/interact/index.php?topic=99370.0
Problem is, I open the terminal, I try to use wget and it says it doesn't recognize the command.
Not sure where to go from here.
Here's the command I am trying to use:
wget -q "http://dist.jriver.com/mediacenter@jriver.com.gpg.key" -O- | sudo apt-key add -
Any help is appreciated!
Usually, it is already there by default in most distribution.
If it not your case, simply do a "apt-get install wget" ...
(05-30-2016, 08:58 AM)martinayotte Wrote: Usually, it is already there by default in most distribution.
It should probably be "sudo apt-get install wget" unless you are running as the root user, which isn't recommended practice.
For some reason, the default Pine64 Debian distro didn't have wget as a default.
Tried apt-get install wget and it worked a treat.
Thanks!
Information Howto: OctoPrint Working on Pine 64 chaos_actual125 22 70,836 07-11-2021, 04:13 AM
Last Post: zer0sig
  Captive portal at school not working on the Pinebook pro WilliamZieg 2 8,246 02-06-2020, 10:41 PM
Last Post: xmixahlx
  Q4OS WiFi Dongle not working cheezmeister 3 8,305 04-07-2017, 08:01 AM
Last Post: iccoldbeer
  HowTo working with MPD and analog sound caragk 3 17,296 11-09-2016, 08:44 AM
Last Post: jkmooney
Exclamation JAVA App. not working correct wrongway 0 3,753 09-14-2016, 11:14 AM
Last Post: wrongway
  Anyone got jackd working? jkmooney 4 10,391 08-27-2016, 08:18 AM
Last Post: pfeerick
  Internet not working properly cezar.suteu@gmail.com 2 7,166 06-17-2016, 01:12 AM
Last Post: cezar.suteu@gmail.com
  Wireless mouse & kbd recognized but not working thehamguy1 9 19,094 05-17-2016, 11:44 AM
Last Post: thehamguy1
