pine64 SDK/library
is there some library for pine64 like what Rpi has where you can read and write information to the io ports?  I believe there is I just couldn't find it.
https://github.com/swkim01/RPi.GPIO-PineA64
(05-28-2016, 07:38 AM)martinayotte Wrote: https://github.com/swkim01/RPi.GPIO-PineA64
Looks cool, could you maybe give a rough tutorial? Smile
Excellent - many people asking about GPIO
Here is a quick example of GPIO LED Blinker :
import RPi.GPIO as GPIO LED_PIN = 26 GPIO.setmode(GPIO.BCM) GPIO.setup(LED_PIN, GPIO.OUT) while 1:   GPIO.output(LED_PIN, GPIO.HIGH)   time.sleep(0.25)   GPIO.output(LED_PIN, GPIO.LOW)   time.sleep(0.25) GPIO.cleanup()
Is modification of GPIO via /sys/class/gpio not supported?
I'm trying to setup GPIO 17 as an output.
I can successfully export 17 as a GPIO, but then when I go to that directory ("gpio17") and try to set its direction, I get "Unknown error 517".
I only have a couple GPIO that I need to use, so I'm wondering if the whole library is worth it, but if there's no other way...maybe I'll have to use it?
You're right ! It seems that there is an issue there.
When I get chance, I will try to investigate ...
(In the mean time, you should probably use the Python library from https://github.com/swkim01/RPi.GPIO-PineA64)
@adamw,
Doing some searches, I found out the cause of the issue : since awhile, the pin numbering scheme in /sys/class/gpio has changed !
See : http://linux-sunxi.org/GPIO#Accessing_th...ine_kernel
Also, here on the forum :
http://forum.pine64.org/showthread.php?t...00#pid4000
On Pine64, the GPIO17 is attached to PC7, so, for the /sys/class/gpio, the numbering would be :
('C' - 'A') * 32 + 7 or 2 * 32 + 7 = 71
You can now give it a try with :
echo "71" > /sys/class/gpio/export echo "out" > /sys/class/gpio/gpio71/direction echo 1 > /sys/class/gpio/gpio71/value
That's great news!
Thanks for sharing.
  Having trouble reading MPU6050 sensor via I²C on Pine64 Jaxon 3 10,606 10-21-2025, 10:13 AM
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 3,832 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 7,252 06-17-2021, 05:35 AM
Last Post: kqlnut
  Just discovered Pine64 ! - first Q philip_rhoades 4 10,452 04-29-2020, 10:13 AM
  A newest user in Pine64 Aliko 1 6,711 04-19-2020, 10:33 PM
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 217,697 01-15-2020, 12:46 PM
  Emails from pine64 received as spam by gmail Matan 2 15,525 08-21-2019, 08:30 AM
Last Post: Leiaz
  How to handle a Pine64 correctly gbjensen 6 23,382 03-28-2019, 11:43 PM
Last Post: InsideJob
Information Creating a NAS server in Pine64 javi_cala 4 12,658 01-21-2019, 02:03 AM
Last Post: bartes
  The 6 most common reasons why Pine64 won't boot Andrew2 109 310,850 10-11-2018, 11:35 PM
Last Post: Technolab88
