DNS Problems with Mobile Data
Same for me, downgrading helped, thank you very much! As I use the phone as daily driver, this quick fix was very important for me.
With this line I also prevent apt from updating libnm0:
echo -en 'Package: libnm0\nPin: version 1.35.*\nPin-Priority: -1\n\n' >> /etc/apt/preferences
In my case after the update there was the mobile ipv6 address and dns missing. Both was send by the mobile provider and I saw it
in the modem manager log. But at adding the ipv6 a fault was shown. After the rollback to the version before anything working again.
Sadly, the latest Network Manager update to v1.36.0-2 hasn't solved the problem. DNS resolving is still broken and a manual DNS server adress is still needed.
(03-03-2022, 01:58 AM)arno_nuehm Wrote: Sadly, the latest Network Manager update to v1.36.0-2 hasn't solved the problem. DNS resolving is still broken and a manual DNS server adress is still needed.
Hi, I've done "apt upgrade" right now and the mobile data is working again.
Before that I didn't change anything in configuration scripts, so for me the new version of Network Manager works correctly now...
Also dbus packages were upgraded but I'm not sure if that could have any effect...
for me the v1.36.0-2 solved the problem, I did nothing else than upgrading, and it's working the whole time now
Thanks for mentioning!
Since I used the workaround via installing resolvconf and adding a new DNS server, I first removed the package resolvconf and then updated network-manager. But it seems, this removed another config file and the DNS server of the mobile provider is still not forwarded into /etc/resolv.conf.
After re-installing resolvconf without manually adding a DNS server, everything works fine after rebooting.
All working again here after this morning's updates. I decided not to try the workaround so didn't need to fix anything else.
Just receive an update of modemmanager too, if I remember correctly the previous version had a bug that used to make me change the APN every now and then.
(03-05-2022, 06:38 AM)grump_fiddle_reinstall Wrote: All working again here after this morning's updates. I decided not to try the workaround so didn't need to fix anything else.
Thanks for report! I had been holding off on updating after reading this issue, but now I feel more confident to go ahead. Smile
Cheers,
TRS-80
Protocols, not Platforms
Same here... Reinstalling resolvconf didn´t help either.
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 7,749 02-20-2025, 02:47 PM
Last Post: puffchumpy
  Mobile internet via cellular network mostly not working Anna 18 26,241 01-19-2024, 02:59 AM
Last Post: anonymous
  Stability problems with 6.1 kernel Zebulon Walton 9 10,225 05-12-2023, 08:09 AM
Last Post: zetabeta
  4G data on default startup / boot dcinoz 1 3,058 04-29-2023, 11:24 PM
Last Post: dcinoz
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 5,294 01-07-2023, 09:36 AM
Last Post: dcarvil
Exclamation No modems were found: No mobile data, no 2G anonymous 2 4,801 12-26-2022, 06:46 PM
  very slow processing of MMS received via Ting (T-Mobile) treebeard 6 8,710 12-01-2022, 09:18 AM
Last Post: traut
  Problems after Tow-Boot Dinosaur1946 3 4,904 09-18-2022, 12:48 AM
Last Post: SpaggettiCoder
  Will this battery-saving script cause problems? rp3 1 3,769 08-28-2022, 02:00 PM
  Tow-boot problems and restoring uboot Zebulon Walton 15 19,585 08-14-2022, 11:09 AM
Last Post: shulamy
