Offline Updates Error
Running stock Manjaro/Plasma Mobile as shipped.
I saw that Discover was telling me there were system updates, so I ran them and got a message to say the phone needed to reboot to complete the installation, but after it rebooted I get a message:
Offline Updates
Failed to update 1 package
Failed to update database: unexpected system error
Then there are 2 options: Open Discover or Repair System
If I open Discover there's nothing there, no errors or additional packages to install.
If I select Repair system nothing seems to happen.
This happens every time I restart the phone - any suggestions?
Yes, suggestion number 1: delete that preinstalled OS so you can boot from sd... it makes a lot of things easier and is recommended at this point of development.
Suggestion number 2: Update with pacman -Syyuu and ignore discovery. It works a thousand times better, is a proven solution and some day when discovery is fixed you can stop doing it through the cli.
Hello
have you try to update from the terminal?
$ sudo pacman -Syyu
maybe you see something more.
"sudo pacman -Syyuu" gives me this:
Synchronising package databases
  core
  extra
  community
error: failed retrieving file 'extra.db' from fast mirror.pp/ua : The requested URL returned error: 404 error: failed retrieving file 'community.db'
then 'too many errors from fast mirror.pp.ua'
skipping for the remainder of this transaction
Starting full system upgrade
there is nothing to do
sudo rm var/lib/pacman/db.lck
sudo pacman -Syyu
(02-17-2022, 01:12 AM)Emilio Wrote: sudo rm  var/lib/pacman/db.lck
sudo pacman  -Syyu
I’m not sure what deleting the lock file would do as I am not getting a error about being unable to lock the database, but happy to give it a try ?
I'm afraid that didn't help (no lock file to delete) but the error regarding fast mirror.pp.ua - that's a Ukrainian server, so maybe there are problems reaching it? If I comment that entry out of the pacman mirrorlist file???
I'm afraid that didn't help (no lock file to delete) but the error regarding fastmirror.pp.ua - that's a Ukrainian server, so maybe there are problems reaching it? If I comment that entry out of the pacman mirrorlist file???
So, commented it out, reran pacman -Syyuu and didn't get an error, but pacman said there was nothing to do - which I guess is good.
Restarted the phone, logged in and got the same Offline Updates error - everything seems to be working fine but I can't work out why Discover is throwing the error and what packages it's complaining about.
Also, the "Repair System" button just doesn't seem to do anything at all!
This is a voyage of discovery for me :-)
sudo pacman  -Syyu
I'm having this exact problem, on a brand new phone. Any solution to this?
The solution is:
sudo rm /var/lib/PackageKit/offline-update-competed
  How Can I Fix This Repo Error dorkydev 1 2,200 11-09-2024, 06:55 AM
  Manajaro Plasma 6 files break unstable updates, 6-30 mburns 5 6,412 07-20-2023, 11:19 AM
Last Post: mburns
Question System Updates: "unexpected error" Greendrake 6 10,073 03-05-2022, 05:15 AM
Last Post: Greendrake
  Error Updating Emilio 2 4,986 02-20-2022, 09:51 AM
Last Post: Emilio
  Notification of Failed Offline Update from Discover tckosvic 0 2,203 02-06-2022, 02:51 PM
Last Post: tckosvic
  No update PGP, Error Solved iopser 2 4,411 02-01-2022, 07:53 AM
Last Post: iopser
