11-21-2021, 08:37 AM
Is there any way how do play DRM protected content in some of Android builds? Netflix works, but other DRM based apps not.
DRM support in Android
02-01-2022, 01:20 AM
It depends upon the manufacture, Like netflix support it. In short, the Android platform provides an extensible DRM framework that allow apps to manage rights-protected content according to the license.
The DRM framework supports schemes is up to the device manufacturer.
02-03-2022, 09:16 PM
Your Android device may come with DRM modules, but this depends solely on the device manufacturer or service provider. Some Android devices simply don't support DRM, but Netflix will still work. Because support can only be provided by some applications. You can check if your device supports DRM by clicking on the link and downloading the program
DRM Info https://play.google.com/store/apps/detai...ng.drminfo. Hope my answer was helpful. All the best to you! |
| Android images for RockPro64 | BitAnnihilator | 5 | 17,852 |
06-04-2024, 11:05 PM Last Post: tllim |
| Difficulty installing Android on Rockpro64 | spammycheese | 0 | 5,700 |
02-17-2023, 05:31 AM Last Post: spammycheese |
| Using Android and the Playstore | grobbs | 0 | 6,040 |
06-04-2022, 12:18 AM Last Post: grobbs |
| Slash TV Android for RockPro64 | Wizzard | 12 | 24,509 |
04-24-2022, 08:13 AM Last Post: Rocklobster |
| Install Playstore on Android 8.1.0 | Domo | 14 | 45,526 |
04-16-2021, 02:13 AM Last Post: Wizzard |
| Install Playstore on Android 7.1.2 | Domo | 6 | 25,090 |
04-16-2021, 02:10 AM Last Post: Wizzard |
| Kodi crashing in Android 9 | Wizzard | 2 | 7,584 |
04-16-2021, 02:03 AM Last Post: Wizzard |
| Install Playstore on Android 9 image | ddimension | 18 | 49,419 |
02-13-2021, 12:52 AM Last Post: chisteven |
| RockPro64 line out/headphones in Android 9 | Wizzard | 0 | 6,054 |
11-20-2020, 04:15 AM Last Post: Wizzard |
| Android 9 drivers | Firesped | 1 | 6,915 |
11-19-2020, 12:39 PM Last Post: Wizzard |
