DRM support in Android
Is there any way how do play DRM protected content in some of Android builds? Netflix works, but other DRM based apps not.
It depends upon the manufacture, Like netflix support it. In short, the Android platform provides an extensible DRM framework that allow apps to manage rights-protected content according to the license.
The DRM framework supports schemes is up to the device manufacturer.
Your Android device may come with DRM modules, but this depends solely on the device manufacturer or service provider. Some Android devices simply don't support DRM, but Netflix will still work. Because support can only be provided by some applications. You can check if your device supports DRM by clicking on the link and downloading the program
DRM Info https://play.google.com/store/apps/detai...ng.drminfo. Hope my answer was helpful. All the best to you!
  Android images for RockPro64 BitAnnihilator 5 18,372 06-04-2024, 11:05 PM
  Difficulty installing Android on Rockpro64 spammycheese 0 5,877 02-17-2023, 05:31 AM
Last Post: spammycheese
  Using Android and the Playstore grobbs 0 6,229 06-04-2022, 12:18 AM
Last Post: grobbs
  Slash TV Android for RockPro64 Wizzard 12 25,335 04-24-2022, 08:13 AM
Last Post: Rocklobster
  Install Playstore on Android 8.1.0 Domo 14 46,531 04-16-2021, 02:13 AM
Last Post: Wizzard
  Install Playstore on Android 7.1.2 Domo 6 25,709 04-16-2021, 02:10 AM
Last Post: Wizzard
  Kodi crashing in Android 9 Wizzard 2 7,848 04-16-2021, 02:03 AM
Last Post: Wizzard
  Install Playstore on Android 9 image ddimension 18 50,667 02-13-2021, 12:52 AM
Last Post: chisteven
  RockPro64 line out/headphones in Android 9 Wizzard 0 6,200 11-20-2020, 04:15 AM
Last Post: Wizzard
  Android 9 drivers Firesped 1 7,101 11-19-2020, 12:39 PM
Last Post: Wizzard
