how to update mobian over tor
sudo apt install apt-transport-tor  tor
 Edit  /etc/apt/sources.list  as root
sudo nano  /etc/apt/sources.list
Make it look as
#deb  http://deb.debian.org/debian bookworm main
deb  tor://2s4yqjx5ul6okpp3f2gaunr2syex5jgbfpfvhxxbbjwnrsvbk5v3qbid.onion/debian bookworm main
Edit  /etc/apt/sources.list.d/extrepo_mobian.sources  as root
sudo nano /etc/apt/sources.list.d/extrepo_mobian.sources
and put    tor+  in front of  the https://repo.mobian-project.org/   url
Uris: tor+https://repo.mobian-project.org/
Who knows why mobian doesn't use the debian-security repository by default?   My mate says it is a good idea to add it to /etc/apt/sources.list
deb  tor://5ajw6aqf3ep7sijnscdzw77t7xq4xjpsy335yb2wiwgouo7yfxtjlmid.onion/debian-security bookworm-security main
Thanks I was looking for this :
(01-26-2022, 02:14 PM)vusra Wrote: Who knows why mobian doesn't use the debian-security repository by default?
this is a good question, I believe it's because it may break the system, the same way as using Debian Sid you don't want the security repo as it's aimed at stable. Please correct me if I am wrong.
https://www.debian.org/security/faq#testing
Quote:Q: How is security handled for testing?
A: Security for testing benefits from the security efforts of the entire project for unstable. However, there is a minimum two-day migration delay, and sometimes security fixes can be held up by transitions. The Security Team helps to move along those transitions holding back important security uploads, but this is not always possible and delays may occur. Especially in the months after a new stable release, when many new versions are uploaded to unstable, security fixes for testing may lag behind. If you want to have a secure (and stable) server you are strongly encouraged to stay with stable.
Why mobian doesn't use the debian-security repository by default?
From my understanding mobian does not use the debian-security repos for the same reason debian testing and unstable don't either. debian-security is meant for stable, and mobian is kind of a wip atm.
According to faq bookworm or testing repo is supported by debian security team https://security.debian.org/debian-security/dists/    Why doesn't mobian use it by default?
(01-17-2022, 01:48 PM)alanwake82 Wrote: Thanks I was looking for this :
I just did the whole thing, but /etc/apt/sources.list.d/extrepo_mobian.sources on mine is empty, should I add the line:
Is it /etc/apt/sources.list.d/mobian.list instead of /etc/apt/sources.list.d/extrepo_mobian.sources ?
(02-06-2022, 05:00 AM)vusra Wrote: According to faq bookworm or testing repo is supported by debian security team https://security.debian.org/debian-security/dists/    Why doesn't mobian use it by default?
Now it got even more important to pay atention to the security aspect: https://blog.mobian-project.org/posts/20...-analysis/
"Disclaimer: while being enthusiastic nerds, none of the Mobian developers is a security expert."
updated instructions for bookworm
make /etc/apt/sources.list look as
#deb http://security.debian.org/ bookworm-security main
make /etc/apt/sources.list.d/mobian.list look as
#deb http://repo.mobian.org/ bookworm main non-free-firmware
deb tor+https://repo.mobian.org/ bookworm main non-free-firmware
  Mobian MMS/SMS text problem bcnaz 16 39,290 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,774 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 68,812 12-24-2025, 12:11 AM
  No touch KB after update(forky) biketool 4 2,473 12-05-2025, 01:15 AM
  trixie update poll questions suggestions j_s 5 3,001 10-22-2025, 07:14 AM
Last Post: anonymous
  cryptocurrency on mobian/pinephone biketool 33 73,619 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,403 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 346,456 06-25-2025, 01:19 PM
  VoIP account on mobian dialer j_s 0 3,075 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,251 06-07-2025, 03:19 PM
