Noob here. Unclear how to flash different distros
Hi there. I'm new.
I see what appear to be conflicting reports of what I need to do in order to boot an img from sdcard.
Seems like it's some combination of:
a) erase emmc
b) hold the power button during boot
c) hold a reset button under the back cover
d) just write an img to an sdcard, pop it in and restart
Can someone please enlighten me? Thanks!
(01-28-2022, 12:40 PM)icantremember Wrote: Hi there. I'm new.
a) erase emmc
If you have the factory image still on the EMMC, you can flash a Pro image onto an SD card and it'll boot from it without any further input. I tried it with Arch SXMO once I got mine and the only issue so far was some serious rumbling in the first 5 seconds of it booting.
The serious rumbling (assuming the vibrator) is a intended feature with the Arch images.
Find me in the forest, when I'm at my lowest. I don't really think you should continue..
HOLD YOUR BREATH.
Some are saying just insert the sd card and start the phone normally
with the 2 second push of the power button.
Myself : after scanning the forum :
I put in my sd card --> and used a 6 second power button press....
Bookworm then booted on my phone.
Bookworm does run good, but there are some problems of course.
Biggest for me is the latest released image does NOT show the boot LED !
This can be difficult ---> watching a black screen --->
When you expect a loading screen.
I can put up with it for now, However perhaps a previous weeks release
may work better for you to install ---> and update later.
(This was using Mobian/Bookworm on my sd card )
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  many distros getting too "heavy" for the PPP hardware; which runs well for you? dchang0 3 2,776 07-18-2025, 04:01 PM
Last Post: dchang0
  I Got A Bit Too Flash Happy (Help) dorkydev 4 4,032 11-08-2024, 09:20 PM
  Which PP distros are live and install easily onto the hard drive? shengchieh 3 3,905 06-30-2024, 10:46 PM
Last Post: Peter Gamma
  Flash Pinephone Pro image from SD card to eMMC? jcun4128 9 15,544 03-11-2022, 09:09 AM
Last Post: fxc
  PSA: Do _not_ flash OG PinePhone OS images to the PinePhonePro Ulfnic 1 3,181 01-27-2022, 09:29 PM
Last Post: bcnaz
