Wifi doesn't respond
I have troubles with wifi which looks like hardware problem. I have PinePhone Brave Heart edition.
I have tried to run different operating systems, but
- 20220119-0503-postmarketOS-v21.12-phosh-13-pine64-pinephone.img.xz
- mobian-pinephone-phosh-20210517.img.gz
- Manjaro-ARM-phosh-pinephone-beta20.img.xz
In attachment is output of dmesg from postmarketos.
And of course I checked hardware dip switch on the back side of pinephone (and tried to turn it off and on again).
I tried to reload module, but it didn't helped:
rmmod 8723cs modprobe 8723cs
Where can I find more debug information?
I can possibly try to check voltage on some pins of the chip, but some guidance would be helpful and I am keeping that as last option.
.txt   postmarketos-dmesg.txt (Size: 40.03 KB / Downloads: 518)
Why such an old release of Mobian ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
I can see at https://images.mobian-project.org/pinephone/ only this version or weekly builds.
Is that version unstable? I just wanted to try if wifi does work in other distros. I can try also weekly build of mobian if it helps. What logs should I attach?
Have you tried the multi-distro SD card image?
https://xnux.eu/p-boot-demo/
(01-30-2022, 03:18 AM)jmlich Wrote: I can see at https://images.mobian-project.org/pinephone/ only this version or weekly builds.
Jan 16  release "should" work just fine,  I have this on my daily use Pine phone and my keyboard phone, both are PMOS Convergent phones.
I have done all the nightly updates as well,  ---> but you could hold back the updates if you are worried about breakage.
I just download the image and flash it to the sd card,  ---> I have not  'attached'  any Logs/files to the sd card(s)
I have NEVER had any wifi problems using Mobian ever,   --> even when it was still called Debian the wifi worked.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
Then it should work with mobian, but it doesn't
(01-30-2022, 02:21 PM)j_s Wrote: Have you tried the multi-distro SD card image?
Will that change something?
I have made yet another test with factory image. See attached picture.
[/quote]
The multi-distro is quite "Cool"
But it does have a custom boot loader,    ==> so it WILL NOT show you how well a particular OS will boot on its own.
It  WILL  show you some of the characteristics of those operating systems.
@jmlich
My Brave Heart is semi-retired,  not enough sim cards for all my Pine phones.
  "The Android test image cannot run your wifi",  ===> that "could be"  a shortcoming of that OS ?  I have not tried that one.
    ( Is that Android test image for the original Pine phones ?)  ===> (maybe try the original Post Market test image ?)
My Brave Heart came with a custom Test OS from the people at Post Market.  ==> (That also installed some of the firmware ! )
Currently  my daily use Pine Convergent phone,  and my Keyboard testing Convergent phone are both operating fairly well
on the Mobian weekly release with all the current updates.  (Not perfect - still improving)
<<< make sure you do not attempt to use the  Explorer Edition Pro phone release of Bookworm,  -- the PRO has a different main board>>>
There are 2 different branches of Mobian now,  one for the original Pine phones  --- and one for the new PRO phones....
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  Kill switches for Wifi/Bluetooth does not work luxgiammi 0 3,107 10-14-2024, 03:34 PM
Last Post: luxgiammi
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 5,368 02-17-2024, 04:15 PM
Last Post: vortex
  bluetooth wifi bugs aular 6 7,408 08-27-2023, 07:53 AM
Last Post: aular
  No wifi/bluetooth on multiple OS's Xxancap15 1 3,498 10-28-2022, 12:10 PM
Last Post: fxc
  Wifi no scan results - Bluetooth adapter not available emsyr 1 3,971 08-29-2022, 02:46 PM
Last Post: emsyr
  Why not Atheros ath9k_htc for wifi? altulke 13 18,795 08-11-2022, 01:01 PM
Last Post: auanta
  Did i break my wifi with the keyboard? captchasolver 5 7,628 02-10-2022, 03:39 PM
Last Post: pothos
  Suddenly WiFi signal strength is poor cinix 4 7,448 09-26-2021, 04:19 PM
Last Post: cinix
  computer doesn't recognize pinephone for OS flashing Xzska-collab 3 7,580 06-29-2021, 09:37 AM
Last Post: Xzska-collab
  Wifi/BT interface not detected aithal 17 29,549 05-30-2021, 11:10 AM
Last Post: Krasimir
