Keyboard causes Pinephone brick?
When I connected the keyboard to my Pinephone, the keyboard didn't work after booting up PostmarketOS 21.12 SXMO. Then after rebooting, the phone hasn't worked again, it's hard bricked. Has this happened to anyone else?
The LED goes from red to amber to white, the phone vibrates, then turns off.  I've tried booting off eMMC, a different SD card, disconnecting the battery, and nothing works, the phone is 100% dead.
I wonder if I got a bad unit, or if this happened due to some HW/SW interaction with the keyboard battery.
That's very concerning. Sorry to hear about your PinePhone. If you have a multimeter or voltmeter or know someone who knows how to use one, it might be worth trying to measure the voltage the keyboard battery is putting out. If it's much too high for some reason, that could explain it.
Make absolutely sure the multimeter is set to measure volts and not current or you could short the battery out!
(01-23-2022, 09:33 AM)acid andy Wrote: That's very concerning. Sorry to hear about your PinePhone. If you have a multimeter or voltmeter or know someone who knows how to use one, it might be worth trying to measure the voltage the keyboard battery is putting out. If it's much too high for some reason, that could explain it.
I'll take some measurements tomorrow and post the results. The phone was from the PmOS batch, which was HW revision 1.2b.
I've also messaged Pine64 support to see if this is a known issue.
Pleas get us informed as i have a keyboard too that is not working but my phone still works after connecting the keyboard.
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 2 4,981 06-04-2026, 12:16 PM
Last Post: elinkser
  Pinephone (Pro) Keyboard Case for sale manubert 8 18,723 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 2,722 01-12-2026, 06:09 PM
Last Post: ragele
  Replacement battery for PinePhone? j_s 9 10,077 06-03-2025, 04:19 PM
Last Post: j_s
  keyboard case charging but not typing new2pinephone 19 26,098 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,254 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 22,349 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Keyboards for the PinePhone? Peter Gamma 1 5,255 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 5,101 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 3,023 07-04-2024, 05:40 AM
