Securely erasing pinephone
Hi all,
I am looking to sell my pinephone and want to securely erase it first, what is the best way of doing this?
I am thinking:
  • Boot from another distro on an SD card
  • Run shred on all partitions on the eMMC
  • Reinstall OS using jump drive image
I think this would work fine but I am wondering
  • Is there a better way of doing this?
  • Is it ok to nuke the eMMC like this or is there firmware, bootloaders etc. on the eMMC that would brick the phone if removed?
Cheers
(01-15-2022, 11:26 AM)Byte Wrote: I think this would work fine but I am wondering
Cheers
depends how you define brick. pinephone ordinary is easier because boot order is sdcard first then emmc. therefore you can nuke totally emmc and is recoverable. pp pro is more problematic because boot order is emmc and then sdcard, even with pp pro, if there is no bootoader on emmc then it's recoverable easily. some rare cases pp pro requires mainboard connectors to disable emmc (this forum has pic for it).
(01-15-2022, 11:26 AM)Byte Wrote: Hi all,
I am thinking:
shred sounds little bit overkill and might be bad for emmc and similar memories which has limited amount of writes. i think just writing zeros or random data once is enough, if you do it for whole disk then it erases partitions as well.
maybe afterwards you could write OS image for convenience.
## showing disks and partitions
# lsblk
# fdisk -l
## this will write random bytes into disk and destroy bootloader and boot sector
# dd if=/dev/urandom of=/dev/sdx bs=1M
Thank you very much, I will use the dd method you suggested
  PinePhone Game Thread PixelPaintbrush 30 79,535 06-04-2026, 01:01 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 21,835 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 6,808 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 7,021 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 909 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 4,132 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 1,640 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 1,280 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 6,652 10-21-2025, 12:12 PM
Last Post: Richy_T
  Does PinePhone support long-term battery health optimization? roseblack 5 3,013 10-06-2025, 09:05 PM
