Fried the charger port and USB
Hi there,
I hope someone out there can help me.
I just fried the single-pin Type H barrel power connector (and adjacent standard USB port) by absentmindedly inserting my Chromebook charger (that has a very similar pin).  The popping sound and bright red flash from the USB port with a burning smell told me that something was wrong Confused
The USB C socket seems ok so I can charge the device but it gives off a high pitched buzzing sound that I don't get when I use the Type H barrel lead. I also think it charges slower but that may be my imagination.  Is there a way of swapping out the charging part so I can fix the problem? It's not the end of the world just annoying that I did this so stupidly.
All help gratefully received,
Leapylee
Is this the Pinebook Pro? If so, this is the "PInePhone" Pro forum.
Find me in the forest, when I'm at my lowest. I don't really think you should continue..
HOLD YOUR BREATH.
  How are people finding the type-A USB 3.0 port? chris88233 1 3,385 10-01-2022, 01:04 AM
Last Post: LivingLinux
  Serial port cable bsammon 17 44,823 03-04-2021, 10:00 AM
Last Post: mattpenn
  Syncwire charger dieselnutjob 1 5,493 02-09-2021, 12:29 PM
Last Post: dieselnutjob
  [SOLVED] Red light flashes next to barrel-port Carl 31 78,726 01-18-2021, 09:34 AM
Last Post: dsimic
  Charging via USB-C Port tyha 15 34,126 07-22-2020, 08:15 PM
Last Post: iscmob
  USB-C to Display Port adapter recommendation 1920x1200 (HP ZR24w) cloudnaut 0 3,458 03-28-2020, 05:58 AM
Last Post: cloudnaut
  Fried eMMC? matega 7 15,281 01-28-2020, 07:53 AM
Last Post: matega
