(ARCHIVED) Ubuntu Xenial Image (BSP Kernel)
jl_678 date[align=justify' Wrote: [/align]line='1462890398']
Wait is armhf Firefox different from the one installed by your Mate install script? That one does not work consistently.
Sure - thats why its the architectures have different names armhf vs arm64.
I am not entirely sure how to install specific versions of FF like suggested here. I will Google it but want to avoid any unexpected gotchas.
Ubuntu is fully multi arch. I think instructions have been posted somewhere in this forum before. Search is your friend.
Thank you for the response. I am off to search. Once I figure it out, I will post the response in a new thread to hopefully help others.
Finally, thank you also for all your hard work on the Pine64 kernel. It is really amazing progress! The latest resolution change functionality in the new kernel was particularly noteworthy from my perspective.
Is there any issue about creating a wifi access point? Options to do it are non selectable grey.
Ehm... Is there anybody in here? [emoji53]
Hi there,
I've managed to install this image and have plex media server running.
I'm trying to mount a 4TB HFSplus drive which I'm currently using with my existing plex media server on a mac mini.
when I tried mounting, i'm getting: mount: unknown filesystem type 'hfsplus'
I noticed in the "**3.10.101-1-pine64-longsleep-41 (20160516)**" changelog that HFS+ support was added but i'm not too sure how do i go about enabling this module.
much help appreciated. thank you in advance!
Something like sudo modprobe hfsplus should do it.
(05-25-2016, 11:42 AM)longsleep Wrote: Something like sudo modprobe hfsplus should do it.
Thank you longsleep for your reply and all the hard work.
I tried that command however i'm getting an error below.
root@pine64:~# modprobe hfsplus
modprobe: FATAL: Module hfsplus not found in directory /lib/modules/3.10.101-0-pine64-longsleep
The image i used was "xenial-pine64-bspkernel-20160507-1"
Has the module been removed in this image, will it be added back or should i grab an older image?
Your Kernel is too old? Why do you even ask, you clearly found the release notes which say it was added in 3.10.101-1-pine64-longsleep but you are running 3.10.101-0-pine64-longsleep??
(05-26-2016, 12:38 AM)longsleep Wrote: Your Kernel is too old? Why do you even ask, you clearly found the release notes which say it was added in 3.10.101-1-pine64-longsleep but you are running 3.10.101-0-pine64-longsleep??
Yes, i clearly realized that after trying to enable the module.
I've not done any compiling myself, only grabbed the latest image from the first post. Is it supposed to come with older version of kernel?
Got the image from below site and I believe that's the latest version of the image.
https://www.stdin.xyz/downloads/people/l...es/ubuntu/
Will there be new images compiled with newer version of kernel or i'll need to compile them myself?
Just run the update scripts. There are plenty of posts in this forum showing how, including the one which lists the release notes for each Kernel. http://forum.pine64.org/showthread.php?tid=293
Ok i got it - you installed the lates Xenial image thinking that it also would have the latest Kernel. That is not not always the case as Kernels are released more frequently. From time to time i release a new Linux image - if required - for the Kernel or U-Boot alone i am not doing that, as those can be updated easily.
  Ubuntu server 20.04 request phi0x 2 11,148 12-30-2020, 08:02 PM
Last Post: phi0x
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 27,613 08-30-2020, 10:35 AM
Last Post: jrronimo
  Kickstarter P64 with LCD, working image? MostHated 1 8,008 01-04-2020, 10:32 AM
Last Post: igorp
  USB Wireless Drivers with Longsleep Linux Kernel jacobscarter 15 41,612 03-06-2019, 02:26 PM
  Allwinner A64 RTC bug fix on bionic image? tkaivola 1 8,550 02-01-2019, 05:09 AM
  SPI on ubuntu IlyaM 4 14,776 07-16-2018, 03:00 AM
Last Post: kingflab
  Ubuntu password not working joemassimino 4 14,381 05-18-2018, 03:33 PM
Last Post: Luke
  How can I get a wireless dongle working on Xenial Desktop latest build Rocklobster 1 6,872 04-16-2018, 03:09 PM
Last Post: Rocklobster
  After flashing Ubuntu- how to get graphical desktop Partymack711 6 17,721 02-01-2018, 09:45 AM
Last Post: Partymack711
  PPTP doesnt work with ubuntu escovedo 2 13,628 08-23-2017, 09:28 AM
Last Post: gilbertotcc
Users browsing this thread: 8 Guest(s)
