Beginner seeking details
#21
(12-01-2021, 03:28 AM)danielt Wrote:
(11-30-2021, 06:59 PM)ronaldheld Wrote: I suppose the originator of the code needs to upgrade to 0.4.1 and create a new .zip file?
That really is up to @graynada .
These days wasp-os has better support for alternative watch faces (https://wasp-os.readthedocs.io/en/latest...apps.faces ) so one option would be to add a themed watch face to the upstream wasp-os repos (although that will lead us to some hard choices because we have more or less run out of flash at the moment).
I have asked @graynada to upgrade to 0.4.1.
I had a thought while waiting for @graynada.  I flashed back to Infinitime 1.7.1.   after the usual procedure to get to Wasp-OS 0.4.1, is there a updated bootloader file I need to flash?
(12-04-2021, 04:46 AM)ronaldheld Wrote: I had a thought while waiting for @graynada.  I flashed back to Infinitime 1.7.1.   after the usual procedure to get to Wasp-OS 0.4.1, is there a updated bootloader file I need to flash?
Which bootloader file... the one that restores mcuboot? IIRC the CI builds do install a newer version of mcuboot than the v0.4.1 versions.
I meant the bootloader file that you would flash after installing 0.4.1 micropython.zip.
Is there an estimate for the next 0.4.x firmware release?
  PineTime beginner MV1791 2 5,122 01-09-2023, 11:52 PM
Last Post: Canyonless
