How to open a terminal on my PC to the PinePhone?
When I connect my Librem 5 to a Linux PC via a USB cable, I can use the command picocom /dev/ttyACM0 on my PC to open a terminal inside the Librem 5. This is very convenient, since it allows me to use my PC's screen and keyboard and to easily cut and paste into the Librem 5 terminal.
However, I can't figure out how to get picocom to work with the PinePhone. How can I open a terminal in the PinePhone on my PC?
I'm currently running Mobian, but I would be interested in hearing solutions for other operating systems as well.
【On your phone】
sudo apt install ssh sudo systemctl enable ssh
Then check your IP address (should be 192.168.x.x, 172.16.x.x, or 10.x.x.x, replace "x" with whatever shows up).
ip a
【On your PC】
ssh mobian@(IP address of your phone)
Then to skip the password (optional step, but very convenient if you frequently login):
【On your PC】
cat .ssh/id_rsa.pub
(Copy the output, if there is none or an error message, generate your SSH key.)
【On your phone】
mkdir .ssh # If not done already nano .ssh/authorized_keys # or vi .ssh/authorized_keys, or vim .ssh/authorized_keys, or mcedit .ssh/authorized_keys etc.
(Paste the output you copied and save the file.)
母語は日本語ですが、英語も喋れます(ry
If you really want a serial terminal rather than ssh you'll need to check how they configure the USB gadget mode. This is more of a pointer for research than a set of instructions as I don't know the details. There's an example in the Mobian wiki for changing between different networking gadgets at runtime using entries under /sys/kernel/config/usb_gadget/g1
https://wiki.mobian-project.org/doku.php...ws-via-usb
There should be a similar way to add a serial gadget.
Once you have a serial interface you need to start getty or similar on the serial port, whether manually or using a service file like getty@ttyGS0.service
  Pinephone visibly losing power while plugged in Hiraghm 10 9,919 10-14-2026, 04:20 PM
Last Post: Flymoon
  Pinephone software Csanderson0313 3 2,063 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 88,643 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 26,869 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 9,045 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,804 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,439 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 3,093 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,477 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 8,918 10-21-2025, 12:12 PM
Last Post: Richy_T
