How to resize the root partition in order to fully utilize the SD Card
Sad
How to resize the root partition in order to fully utilize the SD Card use resize_rootfs.sh script? Huh
(05-24-2016, 04:03 AM)MicroDiery Wrote: How to resize the root partition in order to fully utilize the SD Card use resize_rootfs.sh script? Huh
Yup! Thats what you should do. Open terminal and paste this: sudo /usr/local/sbin/resize_rootfs.sh
Yup! Thats what you should do. Navigate to  /usr/local/sbin and do ./resize_rootfs.sh
Excuse me, do it in pine64 or on computer?
You can SSH into your Pine64 and do it remotely from your computer or you can just open up a terminal window on the Pine64 that is connected to a screen and do it from there.
[edit] just copy and paste this into the terminal: sudo /usr/local/sbin/resize_rootfs.sh
ok,I get it,think you very much
Glad I could help Smile
  root running from usb connected ssd locks up system marcelser 0 4,543 11-17-2017, 04:50 PM
Last Post: marcelser
  OMV base on Debian jessie Root Problem ayamy 3 9,431 09-03-2017, 09:21 PM
  resize root partition to max available space SD card can provide bilylilyli 16 35,116 11-18-2016, 07:10 PM
Last Post: pfeerick
Wink clone copy of sd card by using partclone hatahata 6 14,632 11-04-2016, 12:53 AM
Last Post: pfeerick
  root password shaozhai 4 10,580 08-25-2016, 12:55 PM
Last Post: jl_678
  how to use USB hard disk as /(root) hatahata 15 29,106 07-01-2016, 07:09 PM
Last Post: hatahata
  Debian root's password? rayivy 2 7,162 05-12-2016, 08:59 PM
Last Post: rayivy
  what is the root password for debian? piahoo 5 15,355 04-29-2016, 02:12 PM
Last Post: rhkean
