list of linux native apps/softwares for pinephone on the wiki
Could it be possible to list the linux native apps/softwares for pinephone (or mobile) on the wiki ? They're often distribution independant… Maybe, with a litlle sum up of the working functionalities, a link to some git repo, etc…
Thanks,
alex
I like the idea of there being a central database, but the amount of available apps you can install already is staggering, and each app is at various degrees of usable or broken. I'm not sure even the apps that come preinstalled on each distro are in a state where the devs behind them are satisfied with their performance.
There's tons of moving parts to why apps would not work well either, and sometimes it isn't even the app's fault. Purism's Phosh is still pretty rough around the edges.
It would be awesome though if someone in the community with web-dev experience were to make a community website like https://appdb.winehq.org/ or maybe https://www.protondb.com/ , where everyone can test apps and contribute easily.
There is a page on the Mobian wiki with some apps that work
https://wiki.mobian-project.org/doku.php?id=apps
I'm not sure if it's quite what you're looking for but I find it very useful
There are such lists for Librem 5, and the apps should work at least on a Pinephone with Phosh:
https://source.puri.sm/Librem5/community...evelopment
https://tracker.pureos.net/w/pureos/mobi...ized_apps/
(01-04-2021, 08:14 AM)fsflover Wrote: There are such lists for Librem 5, and the apps should work at least on a Pinephone with Phosh:
That helps, thanks. On the first page there's also a link to
https://mglapps.frama.io/
(01-01-2021, 06:57 AM)alexandre Wrote: Hi,
Thanks,
alex
sudo apk info -v | sort | more
Will give you all packages on your OS.
Shameless self-plug as my project is not listed here yet (it's a fork of MGLapps): https://linmobapps.frama.io
Thanks,
alex
The  Mobian  'Software Store' has something similar,    some of the available software Apps say :  'SAFE reviewed by your distribution'.
These have links to their project websites
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  Pinephone software Csanderson0313 3 714 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 82,605 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 23,576 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 7,651 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 7,677 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,260 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 4,603 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 2,200 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 1,717 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 7,466 10-21-2025, 12:12 PM
Last Post: Richy_T
