Deep sleep shutdown the phone
(10-16-2021, 01:29 PM)dukla2000 Wrote: For Mobian using its default bootloader off eMMC I have no problems.
Hi dukia,
thank you a lot for your response. So just that I am clear before I switch (back) to mobian (I still have it on an sd card, so I will definitively try it - I just want it to be documented here for everyone's sake):
In Mobian, when you do 'systemctl suspend' (or somesuch, I put that in a 1-line-script) or just wait your X configured minutes for deep sleep to kick-in:
1) the phone goes 'off'
2) when you press the power button -shortly-,
3) the phone wakes up again (without showing a boot screen?)
4) you have to login again (I guess - would be fine for me although very aggravating imho)
5) all previously running apps are still running
6) those apps are still useable as-is
7) those apps are still in the exact same state as before step 1)
8) icying on the cake: the uptime is > 0
Is that how it behaves when using Mobian?
Thank you in advance
   lacriz
That is pretty good description of the 'current' Bookworm Nightly fresh install to sd card running on PMOS Convergent phone, just '"Outta the Box"' -- so to speak.
(though at the freshest release there is always a risk of something breaking, but the Mobian Team usually has it fixed by the next release.)
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
I sadly have to report that deep sleep is not working on my 3GB/32GB beta convergence PinePhone. It never has been working, on neither of these distros:
Manjaro + Plasma Mobile (pre-installed)
arch + phosh (from eMMC)
mobian-pinephone-phosh-20210517.img ('stable' image from sd card)
mobian-pinephone-phosh-20211018.img ('nightly image from sd card, flashed that just now)
I can only assume it is a crust issue or somehow dependant on the hardware itself.
I would be kind of interested in advice on how to proceed from here.
However, I somewhat gave up on this issue after spending way too many hours into that topic. I can live with auto-starting firefox, signal, email, calendar and weather app. I set this up using the gnome 'tweaks' app which frees me from having to use the Terminal for such a basic task - which of course no iOS or Android phone even offers Smile
Over-all, deep sleep appears to work for me, but there are some faults, * if the charge is below 15% when it is in deep sleep, it will crash.
It froze a few times a few weeks back, but then the problem disappeared after some updates.
Then again once the night before last it froze, (again the charge was at 15%) after a hard reset it was running again.
This is on the phone I do use as my main phone, the OS was originally flashed about August 15th (I think), with updates since.
>> My test phone that has the most recent nightly release has not had the freezing problem (Yet)
Both are Mobian Bookworm
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(10-18-2021, 11:42 PM)bcnaz Wrote: Over-all,  deep sleep appears to work for me
Hi bcnaz,
thank you a lot for posting your insights.
Would you mind telling us on which exact PinePhone model deep sleep works for you?
Is it the beta edition with 3 GB RAM? Or an older model?
Thanks for clarifying
   lacriz
Are you sure your power button is actually working? I know mine died
(10-21-2021, 01:21 PM)SocialNetworkingWasAMistake Wrote: Are you sure your power button is actually working? I know mine died
I am not sure to whom your question is directed. Sorry for assuming it is me: I -think- my power button works:
1) when I press it shortly, the display goes off / on
2) when I press it for about 20 seconds, a restart is forced
To actually trigger the deep sleep functionality, I know only of 2 ways so far:
a) wait x Minutes (depends on your settings, makes no sense if auto-deep sleep is disabled there)
b) sudo systemctl suspend
Hi bcnaz,
   lacriz
The daily driver is a rev: 1.2a 3g ram,   while the test phone is the rev: 1.2b 3g ram
the 1.2a is the one that I noticed the problem on.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
Thank you bcnaz, now I can rule out that the 3GB-models in general are to blame.
FWIW, I have a 1.2b revision (beta edition).
I followed kqlnut's advice and ran journalctl after a 'wake-from-sleep' boot sequence:
journalctl --since "2min ago"
Here are the -hopefully- relevant messages; does any of that sound familiar to anyone? [How] can I fix this?
Okt 22 12:41:25 danctnix systemd[1]: Activating swap /dev/zram0...
Okt 22 12:41:25 danctnix systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
Okt 22 12:41:25 danctnix systemd[1]: Condition check resulted in Entropy Daemon based on the HAVEGE algorithm being sk>
Okt 22 12:41:25 danctnix systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
Okt 22 12:41:25 danctnix systemd[1]: Condition check resulted in First Boot Wizard being skipped.
Okt 22 12:41:25 danctnix systemd[1]: Condition check resulted in First Boot Complete being skipped.
Okt 22 12:41:25 danctnix systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
Okt 22 12:41:25 danctnix systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Okt 22 12:41:25 danctnix systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
Okt 22 12:41:25 danctnix systemd[1]: Condition check resulted in Create System Users being skipped.
Okt 22 12:41:25 danctnix swapon[2913]: swapon: /dev/zram0: read swap header failed
Okt 22 12:41:25 danctnix systemd[1]: dev-zram0.swap: Swap process exited, code=exited, status=255/EXCEPTION
Okt 22 12:41:25 danctnix systemd[1]: dev-zram0.swap: Failed with result 'exit-code'.
Okt 22 12:41:25 danctnix systemd[1]: Failed to activate swap /dev/zram0.
Okt 22 12:41:25 danctnix systemd[1]: Dependency failed for Swaps.
Okt 22 12:41:25 danctnix systemd[1]: swap.target: Job swap.target/start failed with result 'dependency'.
Okt 22 12:41:25 danctnix systemd[1]: Mounting Temporary Directory /tmp...
Okt 22 12:41:36 danctnix dbus-daemon[2943]: [system] Activating via systemd: service name='org.freedesktop.UPower' uni>
Okt 22 12:41:36 danctnix systemd[1]: Starting Daemon for power management...
Okt 22 12:41:37 danctnix upowerd[3226]: did not recognise USB path /sys/devices/platform/soc/1f03400.rsb/sunxi-rsb-3a3>
Okt 22 12:41:37 danctnix dbus-daemon[2943]: [system] Successfully activated service 'org.freedesktop.UPower'
Okt 22 12:41:37 danctnix systemd[1]: Started Daemon for power management.
Okt 22 12:41:40 danctnix gnome-session[3189]: gnome-session-binary[3189]: WARNING: Could not retrieve current screensa>
Okt 22 12:41:40 danctnix gnome-session-binary[3189]: WARNING: Could not retrieve current screensaver active state: Tim>
Okt 22 12:41:40 danctnix upowerd[3226]: treating change event as add on /sys/devices/platform/soc/1c1b000.usb/usb2/2-1
Without knowing too much of it, it looks like a regular boot sequence. So it would be more helpful to look at the log from the end of the last boot, i. e. when the phone suspended and crashed.
  troubleshooting sleep/wake button on trixie biketool 5 4,851 05-04-2025, 08:11 PM
  phone does not ring (when sleeping) jsch 2 4,740 10-07-2022, 08:08 AM
Last Post: alaraajavamma
  no wakeup from deep-sleep jsch 8 10,506 09-05-2022, 03:03 AM
Last Post: jsch
  MATE on pine phone user641 6 9,449 05-05-2022, 09:44 AM
  Phone mic isn't working at all D347h 2 4,606 01-26-2022, 07:34 AM
Last Post: D347h
  Screen/display gets switched on by itself / Phone wakes up from suspend Anna 5 9,196 01-04-2022, 01:24 PM
Last Post: pothos
  Block Phone Numbers? MarkF 6 10,378 12-02-2021, 08:26 AM
Last Post: Smeegle
  Phone suddenly unusable TRS-80 6 8,177 11-19-2021, 09:46 AM
Last Post: TRS-80
  Mobian and Deep Sleep Crust some_pinephone_user 1 3,981 11-14-2021, 07:05 AM
Last Post: some_pinephone_user
  phone call using built it app will not go to bluetooth motox6 3 7,165 06-28-2021, 11:03 AM
Last Post: wibble
