Rockpro64 Sata Card kills itself
#31
(06-15-2021, 10:11 AM)rantoie Wrote:
(06-14-2021, 12:23 PM)hyc Wrote: Considering that it works fine at 1.5Gbps, maybe it's just bad SATA cables? Or do I really need to junk this PCIe card and get a better one.
Did try to change the SATA cables here, but no difference.
It really seems like the PCIe card is just garbage.
I tried to look around for a Marvell card to try instead, but it will easily cost an additional 80euros to get one, and then I'm not sure if it will make a difference.
I ordered this card yesterday, should get here next week https://www.amazon.de/dp/B07PJFZRRW/
It has 4 SATA ports, but I don't think I'll have any use for the other 2. A shame they didn't come out to the back as eSATA ports. The only cards I saw
with eSATA on the back were all full height.
(06-16-2021, 05:18 AM)hyc Wrote: I ordered this card yesterday, should get here next week https://www.amazon.de/dp/B07PJFZRRW/
This card arrived today, plugged it in and it works fine.
it´s really ashame, 2/2 card bought directly from pine shop and never working. 1 arrived working only on 1 door. 2nd DOA or incompatible.
Really ashame to have an hardware with limited/ no support or totally not wokirng.
My last controller got 2 days ago (after a long shipping time) has not quality control stamp..... this brand sell garbage: I spend hundreds of $ to get the rockpro64 beause of his pci-exp 1x and the nas case.  Sata was basically never be able to run stable. The same with the wifi.
No refund, no support....
the funny stuff is that because of this comment PIne refuse to support my issue...
This is the 2nd card broken or un-usable.
I never read while I pay that I will get no support and that driver etc need to have a pray to get them.
I´m not a unix/linux/openmediavault expert...bit I would feel Ashame for Pine64. Can be really exist a Company like this?
I spent more than 200$ to build the NAS with their hardware. It will be sooner in the garbage!
I will make my emails with the Support of Pine public, not only on this forum if situation is not solved (they black-mailed me....I do the same)
  Powering two disks from RockPro64 some_pinephone_user 3 6,784 02-24-2026, 04:43 PM
Last Post: evilbunny
  TPM module for rockpro64 misha64 0 3,981 12-03-2024, 06:19 PM
Last Post: misha64
  ROCKPro64 Battery Power Supply hoarfrosty 12 15,275 04-01-2024, 10:24 PM
Last Post: nano2
  AW-CM256SM wifi card mtek 4 11,297 10-30-2023, 12:00 PM
Last Post: diederik
  Powering on the Rockpro64 JPT223 1 4,685 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  Which SATA card should I use my NAS server RAID5 Louysa 3 5,919 09-24-2023, 04:40 AM
Last Post: JPT223
  SATA keeps crashing JPT223 1 4,584 09-21-2023, 10:52 PM
  SATA hotplug not working? JPT223 0 3,382 09-15-2023, 04:20 AM
Last Post: JPT223
  Compatible PCIe Sata Controller spacebricker 1 5,607 02-06-2023, 10:03 AM
Last Post: diizzy
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 50,668 12-18-2022, 06:25 PM
Last Post: heyghoge
