Waydroid on Manjaro 16 - how to launch
I'm following these guides:
https://fossingularity.wordpress.com/202...h-beta-15/
and
https://waydro.id/ (scroll down)
so on the first guide, "sudo waydroid-start" says command doesn't exist,
but going to the second guide, "sudo waydroid init" seems to work, but "sudo waydroid container start" and "waydroid session start" seem to get stuck, and subsequently, "waydroid app install whatever.apk" doesn't work either.
was editing boot.txt perhaps an outdated step? Any tips?
iirc Waydroid should have a shortcut in the app drawer now. Does it not show or work to start it?
(10-07-2021, 07:46 AM)tophneal Wrote: iirc Waydroid should have a shortcut in the app drawer now. Does it not show or work to start it?
for me it shows but doesn't start
if the version in the manjaro repos is kept up to date with danctnix's then the instructions likely are outdated. here's the most recent install instructions i've seen: https://fosstodon.org/@xaviers/106936888809418637
(10-08-2021, 07:07 AM)tophneal Wrote: if the version in the manjaro repos is kept up to date with danctnix's then the instructions likely are outdated. here's the most recent install instructions i've seen: https://fosstodon.org/@xaviers/106936888809418637
That's how I installed mine, but still no launch from the icon.
To launch I have to do:
systemctl start waydroid-container --now
sudo waydroid --details-to-stdout container start &       #*note sudo*
waydroid --details-to-stdout session start  &                 # *note no sudo*
Then:
waydroid --details-to-stdout show-full-ui
to see the android gui.  Also if the keyboard is displayed on the screen (pretty likely in a terminal) the waydroid session only fills part of the screen, if you have a full screen app open then it should come up the right size.
Much info can be gleaned fro this reddit post:
https://old.reddit.com/r/PinePhoneOffici...dy_a_game/
  best setup to run waydroid with discord + instagram dustfinger 0 1,554 02-01-2026, 01:41 PM
Last Post: dustfinger
  Can't complete update of manjaro: wwan0 stays disabled; no phone/text gilford 3 4,267 12-05-2024, 06:42 AM
Last Post: gilford
  box86 Actually Works Well on Manjaro Phosh/xfce jakfish 9 11,128 06-30-2024, 12:26 AM
Last Post: Peter Gamma
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 8,899 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  Bumble on Waydroid stozi 1 3,232 01-06-2023, 10:08 AM
Last Post: britelite
  no sdcard boot and manjaro update failed Gwen 3 5,085 11-27-2022, 07:56 AM
Last Post: fxc
  Manjaro phosh no screen rotation sandspur 1 3,771 06-23-2022, 01:02 AM
Last Post: rapp
  Waydroid does not connect to VPN t2moo 0 4,059 05-01-2022, 02:01 PM
Last Post: t2moo
  Manjaro on Pinephone freezes during startup LasVegasLee 1 3,651 03-22-2022, 06:48 AM
Last Post: acrux
  Camera on manjaro arm transfer76 7 11,440 03-18-2022, 10:11 PM
Last Post: Ant
