extlinux.conf file error, can it be edited in bootloader?
Ok, I had a perfectly running Manjaro installed on my PBP eMMC, but decided to update the U-boot to see if it might fix a clock issue I have (likely not but I had never updated that part of the system myself). That went ok, but now instead of a black boot screen until login, I see text regarding the boot sequence. I don't want to see that, so I removed the "console=" bits in the extlinux.conf file per another Manjaro site.
Stupid stupid me, I didn't think to make a copy of the extlinux.conf file, and made a syntax error in the file, and no longer will the system boot into Manjaro!
I can get into the boot command line, but I can't see any way to edit that conf file to fix the problem, no nano, pick, vi... Is the system completely trashed now? I don't have any way to mount the eMMC in another system right now, but I could pick something up from Amazon in a few days...
Try maybe,,, /usr/bin/nano
(09-25-2021, 11:01 PM)wdt Wrote: Try maybe,,, /usr/bin/nano
Thanks, and normally I'd lean on nano as my editor of choice. However, I'm still down in the bootloader, so there's only a limited number of applications I can run. Heck, ls doesn't even work like it does in the OS! Smile
That said, I was able to load Manjaro on an SD card and I was able to boot into it. I was able to mount the eMMC's /boot and edit the conf file. Unfortunately it did not fix the issue, even after I overwrote the original /boot with the SD card's /boot (and grabbed the correct PARTUUID). I can get it to show the splash logo, but it never goes past that point (never gets to login), and if I change the console I get a prompt but the keyboard doesn't work at all.
At this point, I'm just going to grab a few files from my original home dir, and do a full reinstall on the eMMC. Probably good practice; maybe I'll try Gentoo this time!  Big Grin
Thanks all! I've been running Linux on and off since the Caldera days, and I learn something new every day.
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,312 08-21-2024, 04:17 AM
  Error On Initial Setup HankLubowitz 2 3,273 11-21-2023, 05:36 PM
Last Post: igorp
  Suspend/Resume Broken with Bootloader on SPI Flash xp19375 2 4,227 03-24-2023, 04:25 PM
Last Post: srs5694
  Bootloader: SD card boot quirks crazyquark 1 3,206 10-04-2022, 12:27 PM
Last Post: elitegamercody
  Error trying to update Manjaro software boosterh 5 9,072 08-31-2022, 10:28 PM
Last Post: shulamy
  bootloader menu to pick a kernel - what is the current situation in in early 2022? maxtothemax 4 8,276 02-05-2022, 03:04 PM
Last Post: maxtothemax
  PostmarketOS - Why swap file not on at boot? stozi 3 8,802 06-24-2021, 12:27 AM
Last Post: craftyguy
  Good i3 Config file to use? User 22018 6 13,356 06-17-2021, 09:38 AM
Last Post: user526
  Error Log has a few scetchy things. Manjaro Xfce SpaceLord 0 4,270 05-23-2021, 10:49 AM
Last Post: SpaceLord
  Restoring img file to eMMC GloriousCoffee 5 9,825 08-08-2020, 10:49 AM
Last Post: GloriousCoffee
