*urgent help*calls and gnome-conatcs gone after update
I was so happy today with so many packages updates, but after the reboot calls geary and gnome-contacts were missing, I tried to reinstall and got "dipends on packages libfolks-eds25(>=0.14) and libfolks25(>=0.14), but not installable" "impossible to correct the problem, the packages are dammaged and broken" (I was translating the output of the terminal, those may not be exact words)
(09-11-2021, 12:13 AM)user641 Wrote: I was so happy today with so many packages updates, but after the reboot calls geary and gnome-contacts were missing, I tried to reinstall and got "dipends on packages libfolks-eds25(>=0.14) and libfolks25(>=0.14), but not installable" "impossible to correct the problem, the packages are dammaged and broken" (I was translating the output of the terminal, those may not be exact words)
libfolks25 having been removed from testing and some applications under arm have not yet been modified and still use libfolks25, wouldn't it be interesting to temporarily take the mirror of sid for libfolks25?
I have two Mobian phones out of working order at the moment.
My test phone with the September 11 nightly release,  and
My 'driver phone' with September 02 nightly + updates.
IF you have a 'working' phone with mobian installed,  TURN OFF updates until this is resolved !!!
My updated phone can still receive and reply to "existing text messages", but the voice phone will not function, in or out.
No dial pad or contact book.
My test phone has NO communications that function, many areas in "settings" are now grayed out.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
You can download gnome-calls and gnome-contacts packages
change dependencies from libfolks25 to libfolks26 (dpkg-deb -R gnome-calls<blabla>.deb gnome-calls, change a file in DEBIAN directory)
Create package (dpkg-deb -b gnome-calls)
Link libfolks26 libs as libfolks25
Install, it should work
(09-11-2021, 05:17 PM)bcnaz Wrote: IF you have a 'working' phone with mobian installed,  TURN OFF updates until this is resolved !!!
a wise proposal
    A  GUI  Fix !
Big Grin
It may not be a complete "FIX"
But I simply went to the onboard 'Software Store'
and download/installed the 'Contacts'  and 'calls'  apps...
> After a restart the icons are back on the screen where they were.
All the info is in my contacts and even all the recent calls show-up.
 Voice calls both directions and sms text are functioning
What a relief ...
That was using the wifi
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
    A  GUI  Fix !
Big Grin
What a relief ...
It was fixed I could install them this morning...
Here I have the opposite problem.
I'm on Mobian stable, and now geary, gnome-calls, and gnome-contacts cannot be updated due to the lack of libfolks26 (only libfolks25 exists in the stable repo).
Out of the 3, I only use Geary.
母語は日本語ですが、英語も喋れます(ry
hmm...
(after that last update those items did just disappear.)
but
I just browsed the onboard software store, they were listed there, but NOT shown as 'installed'.
So I installed each of them, and everything seems back to normal. ? (after a restart)
OH.... I did not install Geary, at least for now, I am just using webmail for the time being.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(09-12-2021, 10:55 PM)bcnaz Wrote: hmm...
  but
You can install geary from flatpak in worse case scenario
  No touch KB after update(forky) biketool 4 499 12-05-2025, 01:15 AM
  trixie update poll questions suggestions j_s 5 729 10-22-2025, 07:14 AM
Last Post: anonymous
  New camera app gnome-snapshot working on trixie? vusra 4 2,978 04-11-2025, 02:53 AM
Last Post: vusra
  how to update mobian over tor vusra 14 15,988 12-04-2024, 07:01 PM
Last Post: vusra
  Calls 4G not working oliwierzgorniak 2 3,984 08-06-2024, 02:20 PM
Last Post: baptx
  gnome-control-center: segmentation fault on startup jojuma 4 4,321 09-12-2023, 08:49 AM
Last Post: jojuma
  Wifi doesn't work after update nickolas 2 3,523 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 3,793 03-17-2023, 07:26 AM
Exclamation Impossible to login since the latest update anonymous 12 12,356 02-26-2023, 01:01 PM
  No audio on calls after updating today Zebulon Walton 10 12,081 12-12-2022, 09:55 PM
Last Post: BaronAlbatross
