Phone stuck in a login loop
Sad
I received this phone on Sept 2, had a problem with it from get-go. Unless it is connected to a charger it sticks in a login loop. That is: enter password, accepted, display for about 5 seconds, enter password etc, etc. etc..
While the phone was on the charger I tried a software update as suggested. That kept crashing with libcanbera 0.30+2+ unmet dependencies. After a lot of searching I discovered how to update from the terminal with Pacman (always thought that was an arcade game from the ‘70s). That crashed and could not be updated due to locked files which had to be removed using the terminal. This happened 3 or 4 times.
With the last update try I left it over night on the charger.
Update success: but: It is still stuck in the login loop.
Is this PinePhone quality control or did I just get a piece of junk?
Yes, we all got a "piece of junk" if you like to say it so.
Didn't you read all the disclaimers? Especially the software... For developers and early adopters with certain Linux knowledge...
It is always good to search the forum for similar problems Wink
Eg this one: https://forum.pine64.org/showthread.php?tid=14684
Or: https://forum.pine64.org/showthread.php?tid=14172
  Default password for KDE plasma pine phone Toni 0 8,605 09-14-2025, 06:35 PM
Last Post: Toni
  My new phone stopped working. gunnygee 3 5,043 12-12-2024, 01:21 PM
  Pine Phone in Australaa and Telstra tracyanne 2 3,524 12-06-2024, 02:42 AM
Last Post: tracyanne
  Can't complete update of manjaro: wwan0 stays disabled; no phone/text gilford 3 4,667 12-05-2024, 06:42 AM
Last Post: gilford
  2G, 3G still is in phone. Piotr Bujakowski 5 7,163 09-19-2024, 03:49 AM
Last Post: jennybaso
  Looking for the "non-phone" OS wakyct 7 9,576 03-14-2024, 03:51 AM
Last Post: MTXP
  Writing apps/programs for pine phone katesfb 7 13,369 03-11-2024, 10:42 PM
Last Post: Emelia525
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 4,966 01-09-2024, 07:02 PM
Last Post: britelite
  Can the Pine Phone be serviced and updated remotely? profileyourcity 3 5,276 10-02-2023, 05:19 PM
  UBports on pine phone? robb777 16 18,811 09-01-2023, 04:26 AM
Last Post: gregb49
