How to update
Hey guys,
how do I update the Ubuntu Touch image? Do I have to reflash after each new build or can I do it from the settings menu?
Best,
Thomas
(04-09-2020, 04:31 PM)Concrete_panda Wrote: Hey guys,
Best,
Thomas
It's been awhile since I used the UBPorts image but I'm sure there is an update feature in the settings menu. You could also open a terminal and type in:
sudo apt update -y && sudo apt upgrade
I prefer that because I can see what's being updated/upgraded.
Lon
Best,
Thomas
Lon
Thank you, Lon! I am actually a bit surprised, because I know from Ubuntu Touch that I have to remount my root directory before doing that. And to my knowledge, I could not update from the GUI any more if I update this way from the termina.
Did I get something wrong here?
Thomas
I don't think updates work in the gui on pinephone yet. I've been updating through the terminal without any issues. You don't have to mount anything.
(04-10-2020, 04:26 PM)Nooblife Wrote: I don't think updates work in the gui on pinephone yet. I've been updating through the terminal without any issues. You don't have to mount anything.
Great, good to know! Thank you!!
  PinePhone and PinePhone Pro 20.04 Focal Install and Update c3l@ 0 718 05-12-2023, 05:06 AM
Last Post: c3l@
  How to find out about package versions on different update channels? kqlnut 0 1,665 08-30-2021, 01:38 PM
Last Post: kqlnut
  What does an OTA Update look like lsitongia 0 1,556 08-24-2021, 10:20 AM
Last Post: lsitongia
Sad Help! - Screen blank after update. Zweitaktmotor 4 4,497 07-26-2021, 05:17 PM
Last Post: Zweitaktmotor
  Update Channels & Kernel Version mark1250 2 3,187 03-20-2021, 08:26 AM
Last Post: mark1250
  Kernel update failing issues KNERD 5 6,696 01-10-2021, 01:49 PM
Last Post: KNERD
  Kernel Update Channel Zweitaktmotor 2 3,745 01-06-2021, 08:22 PM
Last Post: Korac
  Update process getting more buggy. Cree 0 1,868 08-26-2020, 12:43 AM
Last Post: Cree
  Update Python and get gcc? sunnystormy 2 3,521 08-10-2020, 09:04 AM
Last Post: sunnystormy
  update #41 colin hodsdon 11 14,466 06-08-2020, 06:34 PM
Last Post: pjsf
