Kernel Update Channel
Since switching to the Kernel Update Channel, I have noticed some subtle but important improvements:
- The wifi is still off when the phone wakes up, but it can be switched on much quicker. In the past, I had to switch the wifi slider off and on again and hope for the best, now I only have to tap on my router entry.
- The battery is only charged to about 90%. I heard this is deliberate in order to protect it.
- Battery life is getting quite close to an Android experience. Taking my phone off the charger and using it for 5-10 minutes every hour still leaves me with about 15% after 12 hours. This means I would be able to use the phone all day!
I have not tested calls and sms, simply because my main SIM card is in my other phone. I have a spare one in my Pinephione, but rarely use it. (For users in the UK: I decided to use 1p mobile which is expensive on data but cheap on calls and texts. The best thing about it is that it is a true PAYG, i.e. you only need to top up once every 120 days and then your remaining credit is rolled over).
The only issue that is holding me back from fully switching to the Pinephone on UT is the lack of a usable e-mail client. I have several accounts to check regularly, so Webmail is no good. And Dekko is too buggy to use.
I also find the YouTube developer sessions helpful. The latest can be found here:
https://www.youtube.com/watch?v=RWmXy24X-H4
Enjoy!
I have found that the wifi work but as soon as you go off wifi, the cellular internet does not work. The phone part also does not work. It will say calla fail when trying to make a call. Is there something that Im missing?
Thank You.
Chris
+1 for subtle improvements from Megi's 5.10-rc6 kernel.
A personal favourite from 'kernelupgrade channel/Version 14' is headphone jack detection. It's a small improvement but it is a welcome sight after 4 months of using bash scripts to change active audio outputs.
  PinePhone and PinePhone Pro 20.04 Focal Install and Update c3l@ 0 655 05-12-2023, 05:06 AM
Last Post: c3l@
  How to find out about package versions on different update channels? kqlnut 0 1,609 08-30-2021, 01:38 PM
Last Post: kqlnut
  What does an OTA Update look like lsitongia 0 1,498 08-24-2021, 10:20 AM
Last Post: lsitongia
Sad Help! - Screen blank after update. Zweitaktmotor 4 4,334 07-26-2021, 05:17 PM
Last Post: Zweitaktmotor
  Update Channels & Kernel Version mark1250 2 3,079 03-20-2021, 08:26 AM
Last Post: mark1250
  Kernel update failing issues KNERD 5 6,515 01-10-2021, 01:49 PM
Last Post: KNERD
  Any timeline for kernel 5.8? Djhg2000 3 5,204 10-19-2020, 09:43 AM
Last Post: teknoman117
Star Updates stuck on stable channel. Cree 6 7,556 10-04-2020, 11:26 AM
Last Post: Giiba
  Ubuntu Touch 6 brings camera to RC channel doelf 2 3,970 09-01-2020, 02:15 PM
Last Post: doelf
  Update process getting more buggy. Cree 0 1,826 08-26-2020, 12:43 AM
Last Post: Cree
