Update Python and get gcc?
Hi guys!
I have a Braveheart phone with UBPorts on it and it comes with a fairly old version of Python installed. Is there a way that I can upgrade Python to the latest version? Also, how do I get gcc on this phone as well, it seems like it's not installed either.
Thank you for your help!
It sounds like you'd be better off with one of the other distros that's more like a normal linux install. UBPorts is intended to be more like a phone OS with a read-only root filesystem that gets rewritten with a new version during OTA updates, and all apps installed via its app store. While you can remount root as read-write and use apt or dpkg to install packages, as I understand it this can cause other things to misbehave.
Ah, I see! That would explain things. In that case, which phone distro would you recommend? I’ll have to go buy an SD card, if I’m not mistaken, in order to install a new OS?
  PinePhone and PinePhone Pro 20.04 Focal Install and Update c3l@ 0 717 05-12-2023, 05:06 AM
Last Post: c3l@
  How to find out about package versions on different update channels? kqlnut 0 1,663 08-30-2021, 01:38 PM
Last Post: kqlnut
  What does an OTA Update look like lsitongia 0 1,551 08-24-2021, 10:20 AM
Last Post: lsitongia
Sad Help! - Screen blank after update. Zweitaktmotor 4 4,488 07-26-2021, 05:17 PM
Last Post: Zweitaktmotor
  Update Channels & Kernel Version mark1250 2 3,185 03-20-2021, 08:26 AM
Last Post: mark1250
  Kernel update failing issues KNERD 5 6,684 01-10-2021, 01:49 PM
Last Post: KNERD
  Kernel Update Channel Zweitaktmotor 2 3,742 01-06-2021, 08:22 PM
Last Post: Korac
  Update process getting more buggy. Cree 0 1,865 08-26-2020, 12:43 AM
Last Post: Cree
  update #41 colin hodsdon 11 14,436 06-08-2020, 06:34 PM
Last Post: pjsf
  A Few Issues After OTA-12 Update falkensmaze 2 3,942 05-14-2020, 12:31 PM
Last Post: falkensmaze
