on-board ethernet driver
I am trying to build a system based on buildroot for the Rock64. It appears that the Ethernet driver is not insmod
# lsmod
Module                  Size  Used by    Not tainted
ipv6                  425984 16 [permanent]
Could someone please help me with reference from other distributions that has a working ethernet driver source & the init.d scripts that load all the kernel modules for the Rock64.
Thanks,
-Michael.
  using on-board sensors Mentaluproar 0 3,047 07-17-2020, 12:00 AM
Last Post: Mentaluproar
  Ethernet latency nethammer 1 4,428 10-17-2019, 05:15 PM
Last Post: nethammer
  Gigabit Ethernet problems aaronw 2 8,648 02-16-2019, 03:04 AM
Last Post: uttam
  8812au wifi driver OS pane 9 19,246 11-19-2018, 02:46 AM
Last Post: pane
  Cannot make DAC Add-on Board work under debian szclsya 0 3,051 09-29-2018, 12:57 AM
Last Post: szclsya
  OMV wifi setup (driver issue) six9 0 4,006 07-25-2018, 03:34 PM
Last Post: six9
  rtl8812au driver install.. 11b2p508 11 26,444 05-20-2018, 01:36 AM
Last Post: brajul
  How can I get a driver to support my USB wifi dongle Rocklobster 4 9,917 04-19-2018, 12:55 PM
Last Post: Rocklobster
  Compiling and installing Wifi driver Lexstar 20 35,052 02-15-2018, 04:48 AM
Last Post: cooker
  I can not build a Wifi driver in the kernel pine3228 3 6,324 01-06-2018, 11:17 AM
Last Post: xalius
