Gigabit Ethernet problems
Hi all,
I have my Rock64 plugged into a gigabit switch along with my host computer. After adding the fix for the USB power problem I ran into an issue where ssh would frequently hang and I could not even run vi or remote X  tools. Even aptitude would hang when I attempted to search.
Anyway, I was able to fix the problem by installing ethtool and running ethtool eth0 -s advertise 0x008
This forces the board to only use 100Mbps instead of gigabit. My guess is that there may be something misconfigured in the MAC or PHY driver for this board, preventing large data transfers over gigabit (perhaps inter-packet spacing or something like that is wrong).
-Aaron
Look at this thread: https://forum.pine64.org/showthread.php?tid=5093
Workaround:
ethtool -K eth0 tx off
Works with 4.4 kernel only (4.4.77-rockchip-ayufan-133).
Does not work with mainline kernel (4.14-rc6) - still GbE problems.
(10-28-2017, 04:17 AM)maal Wrote: Look at this thread: https://forum.pine64.org/showthread.php?tid=5093
Workaround:
Changing the cable to Cat6 solved the issue for me. Cat5e 4 pair cable gave Gbe on my laptop by 100Mb/s only in rock64, tried another cat6 cable and rebooted and it now shows 1000Mb/s with ethtool.
  on-board ethernet driver michaelanburaj 0 1,862 03-26-2020, 12:01 PM
Last Post: michaelanburaj
  Ethernet latency nethammer 1 2,626 10-17-2019, 05:15 PM
Last Post: nethammer
  Problems with USB 3.0 and SATA disk (UAS) diglam 6 11,654 10-16-2018, 11:05 AM
Last Post: Trash_Can_Man
  USB3 problems scalextrix 2 4,049 09-08-2018, 01:15 AM
Last Post: scalextrix
  Stock debian image - rock64 - gigabit rhille 11 14,250 08-29-2017, 07:48 AM
Last Post: rhille
  Xenial Mate: Screensaver Preview & LibreOffice Slideshow problems moravecz 2 3,369 08-27-2017, 10:37 PM
Last Post: moravecz
  Broken yellow Ethernet light? jl_678 1 2,940 08-27-2017, 04:23 PM
Last Post: MarkHaysHarris777
  Gigabit Ethernet performance testing fire219 0 4,756 07-02-2017, 07:12 AM
Last Post: fire219
