no wifi / mobil
Is it normal, that the modem (wifi and SIM) isn't working when  booting with removed batterie ??
could pls someone try booting without batterie (onyl with power via USB wire) and check if wifi / mobil network is working ??
Thx
Yes, it is normal. WiFi and battery is powered directly from the battery, as stated in the Wiki.
(03-24-2020, 10:28 AM)Alho Wrote: Yes, it is normal. WiFi and battery is powered directly from the battery, as stated in the Wiki.
AH, OK, haven't seen that in wiki. Thx for information.
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 535 02-17-2024, 04:15 PM
Last Post: vortex
  bluetooth wifi bugs aular 6 1,498 08-27-2023, 07:53 AM
Last Post: aular
  No wifi/bluetooth on multiple OS's Xxancap15 1 1,125 10-28-2022, 12:10 PM
Last Post: fxc
  Wifi no scan results - Bluetooth adapter not available emsyr 1 1,402 08-29-2022, 02:46 PM
Last Post: emsyr
  Why not Atheros ath9k_htc for wifi? altulke 13 6,676 08-11-2022, 01:01 PM
Last Post: auanta
  Did i break my wifi with the keyboard? captchasolver 5 3,189 02-10-2022, 03:39 PM
Last Post: pothos
  Wifi doesn't respond jmlich 6 4,179 02-04-2022, 06:50 PM
Last Post: bcnaz
  Suddenly WiFi signal strength is poor cinix 4 3,515 09-26-2021, 04:19 PM
Last Post: cinix
  Wifi/BT interface not detected aithal 17 14,800 05-30-2021, 11:10 AM
Last Post: Krasimir
  WIFI not available after anx7688 update failure frimmel 21 19,484 05-11-2021, 02:45 AM
Last Post: frimmel
