Screen recorder
I am trying to record the screen of the Pinebook Pro with audio from the webcam mic.
I tried Kazam, but it can only record in AVI (huge file and audio died after 30 seconds!) and not with h264.
I'm testing with FFMPEG, but I get audio drops and the image quality is not what I hoped for.
This is the command I'm using at the moment:
ffmpeg -video_size 1920x1080 -framerate 30 -f x11grab -i :0.0 -vcodec libx264 -c:v h264_rkmpp -thread_queue_size 32 -f alsa -ac 2 -i hw:0 output.mkv
Anyone has a working solution for recording the screen, or knows how to tweak FFMPEG?
I also installed the package x264 from the Synaptic Package Manager.
I was watching a Youtube video from LearnLinuxTV and I noticed he used SimpleScreenRecorder.
That one gives a decent result.
It reports around 13 fps, so I guess 30 fps isn't possible, until we get hardware encoding running.
ffmpeg can also do it, see x11grab in the man page.  Not exactly a GUI user-friendly program but I've done it a couple times.  You can grab just part of the screen I think.  But computer screens with mostly low numbers of colors and sharp contrasts don't work well with mpeg which is a little like jpeg that way.
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 297 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Black screen by start up bluedemon382 10 2,967 07-27-2023, 07:49 AM
Last Post: dstallmo
  PBP blank screen after updating Manjaro Franko 6 2,019 04-01-2023, 07:55 AM
Last Post: hacknix
Question Pinebook Pro shows only bright white screen when powered on Sean Whitton 3 2,000 07-22-2022, 01:19 PM
  Ring around screen following update tylerjohnson3208 2 2,096 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Looking for Screen LCD Panel for the Pinebook Pro gerstavros 3 2,749 05-09-2022, 05:53 AM
Last Post: gerstavros
  Putting my screen on TV S265 6 4,751 10-07-2021, 08:00 PM
Last Post: ajawadmahmoud
  Screen refresh delay with kernel errors shawnanastasio 31 38,761 04-27-2021, 02:57 AM
Last Post: james64
  Novice question: Pinebook Pro does boot (does it?) but black screen Gert V. 21 19,636 01-27-2021, 10:48 PM
Last Post: rimaille
  Screen flicker with USB-C charging bchenlee609 5 5,887 01-25-2021, 08:48 PM
Last Post: bchenlee609
