Battery problem solution?
So far, we have learned how to switch the modem on via terminal commands to enable phone calls and texting.
However, it seems that the phone battery drains very quickly when this is on. Somebody mentioned power management to be developed.
Here is something else that occured to me:
On my Android phone, making phone calls and using mobile data are two very different things. Phone calls/texting is always on if I have a sim card inserted, but mobile data can be switched on and off. If it is on, it drains the Android phone battery just as badly as my Pinephone.
Can these 2 functions be separated on the Pinephone as well?
At the moment, my notification area (in Postmarket OS) shows 3 symbols:
- phone signal strength (vertical bars)
- 4G (mobile data)
- Wifi signal strength (scope bars)
If I was able to switch "4G" off but keep the other two going, I am sure it would improve battery life.
Is there any terminal command that can do that?
The underlying method will be the AT commands, but doing it that way may cause confusion on the higher level interfaces. At the top you've got NetworkManager / ModemManager, or connman, depending on distro. In between those and the AT commands you have Ofono. These should be able to turn off the mobile data while leaving the voice/text interface on. I'd hope that would reduce power consumption, but it depends what's going on inside the modem firmware.
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 541 02-17-2024, 04:15 PM
Last Post: vortex
  Battery life improvement freelectro 10 3,324 06-01-2023, 08:27 PM
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 1,529 03-20-2023, 12:54 AM
Last Post: bcoyle
  Power supply vs battery albafrati 11 4,661 06-22-2022, 06:04 PM
Last Post: albafrati
  What PD charger/dock combo results in PP battery not draining while using convergence james8880 0 1,465 04-28-2022, 12:45 PM
Last Post: james8880
  Battery mot charging past 54% StickyPine 32 26,217 02-26-2022, 02:07 AM
Last Post: vusra
  Pinephone time goes too slow (not a 2115 year problem) grwlf 1 1,681 02-06-2022, 05:05 AM
Last Post: grwlf
  Battery replacement alternative sax1960 7 6,328 08-29-2021, 07:03 AM
Last Post: bcnaz
  Battery Capacity and Software Interaction food 2 2,425 08-15-2021, 07:19 AM
Last Post: bcnaz
  Battery phone case expected? Cpm 1 2,098 08-10-2021, 03:29 PM
Last Post: 33YN2
