What PD charger/dock combo results in PP battery not draining while using convergence
I could not find an already existing thread and so I am writing this one.
My set-up results in the battery slowly draining until no charge and I am forced to end my session with convergence because the phone shuts down when all of the power in the battery is gone (of course ) Smile.
I am using:
  • HDMI cable to monitor
  • 5.17.2-1-danctrix - April 10 build
Seems to me that the Anker is not passing enough power through to the PP in order for it to charge up the battery.  Perhaps there exists a dock that is more efficient and does pass enough power to the Pinephone.  The PinePower connected directly to the PP does charge the PP battery up very well, as expected.
Is there a combination of PD and dock that will result in the PP battery charging up while it is docked with HDMI output?
I am aware that there may be software issues involved as well.  I think that the software performs negotiation with the PD to set the phones level of power draw from the PD.
Perhaps that software does not "know" how to negotiate power levels from the Ankler dock but it does know how to do that with the PinePower. idk
Thank you for your time and knowledge,
James
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 535 02-17-2024, 04:15 PM
Last Post: vortex
  pinephone keyboard + dock question tuxcall 7 2,782 02-05-2024, 03:17 PM
Last Post: wigan
  Battery life improvement freelectro 10 3,304 06-01-2023, 08:27 PM
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 1,528 03-20-2023, 12:54 AM
Last Post: bcoyle
  No calls on Pine Phone Beta convergence edition polypode 1 1,174 03-06-2023, 08:04 PM
Last Post: rocket2nfinity
Lightbulb Insta-Shutdown w/o Charger Techpaint 0 695 10-14-2022, 07:30 AM
Last Post: Techpaint
  Wifi no scan results - Bluetooth adapter not available emsyr 1 1,403 08-29-2022, 02:46 PM
Last Post: emsyr
  Power supply vs battery albafrati 11 4,657 06-22-2022, 06:04 PM
Last Post: albafrati
  Issues with HDMI-out from convergence dock folgaran 1 1,200 06-16-2022, 04:35 PM
Last Post: alaraajavamma
  kb151 2-0015: Charger read failed - MCU returned 0xff as365n4 5 2,807 06-08-2022, 10:41 AM
Last Post: as365n4
