Insta-Shutdown w/o Charger
Lightbulb
Greetings,
linux/tinkering newbie here; assistance from more skilled is appreciated!
Per title: device shuts down immediately without power source; even during boot. It says 100% in SXMO postmarket os.
Reinstalling pmOS on MMC made no difference. dmesg contains no useful entries as far as I know...
Had it for a couple of weeks.
Battery itself's fine (works on other pinephone - ordered convergence too).
The issue appeared after swapping the battery from convergence model. Next morning, device wouldn't boot without power source. Single PineKeyboard had been used with both devices.
Is this an early hardware fault? Any ideas what may the issue be? Charger used should be in range (5V, 1.5A).
Thanks lots!
Exclamation PP v1.2a charges only if shutdown before connecting to USB mikeb 0 669 08-19-2022, 02:18 AM
Last Post: mikeb
  kb151 2-0015: Charger read failed - MCU returned 0xff as365n4 5 2,792 06-08-2022, 10:41 AM
Last Post: as365n4
  What PD charger/dock combo results in PP battery not draining while using convergence james8880 0 1,457 04-28-2022, 12:45 PM
Last Post: james8880
  Raspberry 4 Charger for Pinephone? jojuma 8 7,580 01-01-2021, 11:48 AM
Last Post: wibble
  Can't turn off phone..Hard shutdown? JLane8 6 7,368 09-13-2020, 01:53 AM
Last Post: JLane8
