Improving charging of PBP battery
I've read a ton of threads and see a lot of discussion around charging/discharging, links to Amazon power supplies, links to Pine64 usb to to barrel adapter.
Is there an incoming wiki section on charging solutions? Similar to the NVMe wiki section... basically a wiki section that confirms which barrel chargers work  and which usb type-c chargers work well?
Due to my location shipping will be a pain. Otherwise I would happily be a guinea pig and report back suggested power supplies on Amazon.
No mater what you use, you are limited to 15W charge...
I have a 65W USB-C charger for my Surface, and it makes no difference on charging the PBP. Just use the original one. It charges faster if it is turned off.
(02-03-2020, 07:54 AM)krigl Wrote: Just use the original one.
I think a lot of people are looking for alternatives, not for faster charging, but simply due to the fact that the included charger cord is absurdly short. I have an outlet pretty close to my desk at home and the cord is not even long enough for me to charge the PBP on my desk. I have to set it on the floor for the cord to reach.
Ok so then you can use any USB-C adapter with 5V/3a rating. It can be more then 15W with no issues.
grab a stable thread and 2 nails, then get an multi-extension cord and suspend it with the thread @10 cm below your table. you'll be surprised, how nice it is, to not have a super long cord  Angel
Star
(02-03-2020, 10:35 AM)krigl Wrote: Ok so then you can use any USB-C adapter with 5V/3a rating. It can be more then 15W with no issues.
Send me a link to one of those USB-C adapter with 5V/3a rating.
Basic adapters as you mentioned, no fast charge. Just straight 5v/3a.thx
I am using a few different USB-C pd chargers I already owned for my pixel 2 xl - one cable is 10ft and it is awesome.
the included cord is uselessly short.
FAST charging and multipurpose. USB-C for the win.
https://www.ebay.com/itm/Tecnoware-Alime...SwW-heM~lY
This is the one I have..
It is cheap enough and also as I already said it is also 65W for charging my surface quickly.
REMEMBER :
The 5 volts DC volt will drop voltage very quickly with length !
** You want to extend the input cord
NOT the OUTPUT cord !
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  Lithium Battery Connector Franestra 0 127 04-02-2024, 01:52 AM
Last Post: Franestra
  Bad replacement battery? chris88233 3 393 02-19-2024, 04:59 PM
  Bypassing the Battery gilwood 0 247 02-01-2024, 10:45 AM
Last Post: gilwood
  Pinebook Pro charging issues tomekdev 1 615 01-05-2024, 08:40 PM
Last Post: tomekdev
  PBPro Battery specification Perl6_user 3 580 12-26-2023, 04:28 PM
Last Post: DrYak
  Replacement battery for PineBook Pro DrYak 3 1,086 11-07-2023, 10:09 AM
Last Post: DrYak
  Battery replacement mjc 2 2,895 09-26-2023, 01:08 AM
Last Post: david-lechner
  Battery drain when off srs5694 1 1,028 03-24-2023, 06:05 PM
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,799 07-09-2021, 08:45 PM
Last Post: moonwalkers
  Battery doesn't charge mspohr 5 5,327 06-11-2021, 08:42 AM
Last Post: mspohr
