RockPro64 + Kodi + POT
I'd like to build myself a media center.
As software I would like Kodi / libreElec or something based on Debian (it's the system I know best).
As hardware I would have thought a RockPro64 4Gb.
Also I would like a quality audio output: I have seen some POT boards but I didn't understand how to use them and if they are compatible with RockPro64 and libreElec.
I would use an eMMC for the operating system but all media files would reside on a separate nas.
I would control everything with the web interface
Do you have any suggestions? Will it work ;) ?
Thank you,
Rickyx
(02-03-2020, 05:08 AM)rickyx Wrote: Do you have any suggestions? Will it work Wink ?
I use libreelec with kodi on my rock64 set top box which streams media files from my nas, so yes it does work.
The rp64 is 3x faster than the r64...
Thank you, I'll go that way!
...what about POT boards?
I could not find more info about
Dac boards are for R64 only.
But it only works using Volumio: is it still true?
I'm still wondering what to buy.
(02-06-2020, 04:40 PM)rickyx Wrote: Dac boards are for R64 only.
I would get an r64 - for your use case an rp64 is probably overkill.
  New RockPro64 Power Up Problem enorbet2 7 5,102 10-28-2023, 12:08 PM
Last Post: dkebler
  Rockpro64 disappointment Paulius 2 967 09-27-2023, 08:09 PM
Last Post: TRS-80
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,720 08-07-2022, 10:47 AM
Last Post: commiecam
  RockPro64 ethernet issues: DMA engine initialization failed slowcamp 1 3,101 04-26-2021, 06:03 AM
Last Post: slowcamp
  howto power hdd via usb3 on rockpro64 hanscees 2 5,113 06-17-2020, 02:00 AM
Last Post: hanscees
  The differences between Rock64 and RockPro64 phamoanh 1 4,417 06-12-2019, 10:44 PM
Last Post: evilbunny
Question PineH64, RockPro64, LUKS Encryption, Urbackup Speed? CoMcE 3 5,927 02-06-2018, 04:39 PM
  Kodi on Rock64 board cenguix 2 8,899 02-02-2018, 03:05 PM
Last Post: stuartiannaylor
  Best OS for KODI AdamK 2 5,455 07-08-2016, 11:46 AM
Last Post: lenny.raposo-pine64.pro
