howto power hdd via usb3 on rockpro64
I am looking what I would need to build a NAS with a large 4tb sata hdd 3,5" using usb3 only
My setup would be:
1- A rockpro64 with 12v adapter
2- A powercable for sata drive  https://store.pine64.org/product/rockpro...ta-drives/
3- an external hdd drive 12v 4 tb
I do not need ssd speed so using usb3 should work.
4- so  I was considering using the usb3 to sata adapter for the rock64 https://store.pine64.org/product/usb-3-0...with-uasp/
However, it is not clear to me if this usb3 cable is compatible with using the powercable for sata drive of the rockpro64?
Can anybody explain what I need to power a hdd sata drive via the usb port of the rockpro64 please?
Thanks!
(06-11-2020, 02:15 PM)hanscees Wrote: Hi,
My setup would be:
Thanks!
You cannot combine both cables to operate external HDD drive, this due to only Sata Cable already occupied both Data and power port. However, if you plan to power +12V to your external HDD (assume is 3.5" type), just plug in 12V 2Aor above power thru the 5525 DC Jack at the side of the Sata power cable.
My setup would be:
Thanks!
The problem why I need to ask this here is the incomplete information in the pinestore with regard to sata cables. There are no photos where you can see the pins of the connectors so I cannot see if they connect both power and sata or only part of it.
In the case of the usb3 to ssd cable this is clear, but why don't you deliver a fitting powersupply, since there is no way for a buyer to know what powersupply would fit.
Another option for improvement of your store would be to publish a howto on "making a NAS for begin to start with rock64 and rock64pro".
Just minor issues of course, but it might help some clueless folks (like myself Smile).
In the meantime I came up with a new idea:
combine rock64 with an external usb3 casing solves the power problem, something like this:
https://tweakers.net/pricewatch/729487/e...ificaties/
for a NAS with 3,5" external sata hdisk usb3 on ssd rock64 is fast enough probably.
Since the rock64 is half the price of the pine64pro, but still has gb network and usb3 (but no sata)  that makes sense.
If there is a good howto on howto make a NAS from A-Z please let us know!
Found one here:
https://midstar.home.blog/
  New RockPro64 Power Up Problem enorbet2 7 4,985 10-28-2023, 12:08 PM
Last Post: dkebler
  Rockpro64 disappointment Paulius 2 918 09-27-2023, 08:09 PM
Last Post: TRS-80
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,697 08-07-2022, 10:47 AM
Last Post: commiecam
  RockPro64 ethernet issues: DMA engine initialization failed slowcamp 1 3,086 04-26-2021, 06:03 AM
Last Post: slowcamp
  Pinecil power Erincka 0 1,855 03-21-2021, 11:52 AM
Last Post: Erincka
  Session fails to fully start after unexpected power off during initial upgrade Avron 0 1,929 03-18-2021, 11:52 AM
Last Post: Avron
  Power button sdziuba 1 2,409 03-14-2021, 09:05 AM
Last Post: xalius
  PBP won't power. Charge light solid orange/red but turns off. cmicallef 15 12,327 03-12-2021, 07:08 PM
Last Post: cmicallef
  RockPro64 + Kodi + POT rickyx 4 7,196 02-06-2020, 10:03 PM
Last Post: clach04
  User Screen Black After Changing Power Settings 0b51Gekko 2 4,746 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
