Issues with "recovery" button
I tried using tux's intructions with a usb-c -> usb-c cable tonight, both pbp's. didn't work.. will try usb-a to usb-c tommrow.
USB-A to USB-C did work with the ld command, but when i tried to flash the db file, i kept getting "Creating Comm Object failed!" so i decided not to proceed any futher. is this the expected output? i also tried running the command with sudo, but got the same response. tried both tux and as400's files. perhaps the pinebook usb-3 port does not provide enough power to run this command?
I just tried the spi flash and i think i've really done it this time... lol
~> rkdeveloptool ld
DevNo=1 Vid=0x2207,Pid=0x330c,LocationID=1402 Maskrom
~> cd PBPBoot
~/PBPBoot> rkdeveloptool db rk3399_loader_spinor_v1.15.114.bin
Downloading bootloader succeeded.
~/PBPBoot> rkdeveloptool wl 0 spiflash.bin
Write LBA from file (100%)
~/PBPBoot> rkdeveloptool td
Test Device OK.
~/PBPBoot> rkdeveloptool rd
Reset Device OK.
Edit: nvm, it works! it took a while and a few power cycles to figure everything out but i can boot from emmc at least.
  Issues with T-Mobile Home Internet? skinnyonthebebop 3 1,091 10-17-2023, 07:42 AM
Last Post: skinnyonthebebop
  Got a PBP - batch(August/September) and the audio is not good(2 big issues) crazyquark 2 1,503 10-01-2022, 10:16 AM
Last Post: crazyquark
  MiniConda Install Issues nixyhustle 0 793 09-16-2022, 10:06 PM
Last Post: nixyhustle
  new PBP issues jpjnh 9 3,917 08-22-2022, 07:26 AM
  Issues with External Display After Recent Update reundo 0 1,380 11-18-2021, 06:37 PM
Last Post: reundo
  HArdware issues while charging user18130814200115 2 2,839 05-01-2021, 04:13 AM
Last Post: gabeeg
  Issues with chromium-docker PVD 4 6,413 12-17-2020, 10:11 PM
Last Post: warehouses
  App installation issues on PBP pineitup 0 1,695 10-21-2020, 06:23 PM
Last Post: pineitup
  issues with keyboard/trackpad in Manjaro, can't test other OSs joshw 11 12,885 06-25-2020, 08:11 AM
Last Post: joshw
  Intermittent Boot Issues MrRoosevelt 19 18,497 06-21-2020, 06:45 AM
Last Post: khanku
