rockpro64 buzzing sound when running
I just bought a rockpro64 board to build myself a little NAS (for fun and education purposes). However, I've noticed that when the rockpro64 is plugged in and running, it makes a buzzing sound. Not too loud, but audible if I put my ear near the board; makes me concerned about a faulty capacitor. Is this normal? Does anyone else hear this?
I've tested this without any components plugged in (except an emmc module). I'm using the 30mm tall profile heatsink, and the stock sockpro64 12V 5A US power supply.
Just want to make sure I'm not going to have a problem with the board soon (or fire hazard)! Let me know if anyone has experienced this or if I should try to send it in for replacement.
Thanks!
Many of electronic devices are equipped with DC/DC converters. And may be in more than a half cases you may hear the vibration of converter components being very close to the board. Usually these sounds are quite enough to be not noticeable.
If you hear the sounds at a distance, say, 0.4m, it is unusual. I'm hearing none from mine ROCKpro64. You may try to touch and slightly press the inductors and the capacitors on the board, one by one, to determine which component is most loud and is changing it's sound when being touched.
  ROCKPro64 Battery Power Supply hoarfrosty 12 2,055 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 909 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 25,894 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 859 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 1,647 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 6,714 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 1,158 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 5,441 07-18-2022, 10:05 PM
Last Post: zer0sig
  RockPro64 premium aluminium casing justwantin 2 2,177 05-27-2022, 06:51 PM
Last Post: justwantin
  charging 3 rockpro64 from single source rpt312 1 1,754 05-16-2022, 02:34 AM
Last Post: dukla2000
