RockPro64 premium aluminium casing
I'm considering ordering a RockPro64. There is an aluminium case for it that has a "Built-in heat pipe (plate) that directly contact[s] with SoC". Has anybody used one of these cases and does it provide adequate cooling?
If that is the case than I would probably first install Slackwarearm out of the case and then install the board in the case after the install. Would installing without a heat sink or heat sink with fan pose a risk of overheating and damaging the SoC?
At 65F ambient, this is the output of the 'sensors -f' command (package lm_sensors in Manjaro) :
Idle 87F
1 thread running at 100% CPU: 95F
2 threads: 97F - 98F
3 threads: 99F -100F
4 threads: 100F - 102F
5 threads: 121F
6 threads: 133F (56 C)
That's with 0 GPU load on a headless server, so it can go higher if you run a GPU-intensive application as well.
It takes a while to heat up due to the thermal mass of the case, and air movement from room fans produces a lower steady-state temperature.
Miners run GPUs at 56 - 71C and don't expect damage below 90+ C.
Whether the case provides adequate cooling will depend on your ambient temperatures and usage. 120F summer in Iraq with no A/C, or McMurdo?
I don't think install & configuration will heat the bare board up much. You can keep an eye on it with 'sensors' and point a desk fan at it if it's really necessary.
Thanks for that! ... also asked on the Slackware-Arm forum and drmoses (who maintains Slackware-Arm as well as contributes to Slackware in general) advises much the same. I just ordered and after familiarisation I'll use the RockPro64 as a NASM.
https://www.linuxquestions.org/questions...175712672/
  Powering two disks from RockPro64 some_pinephone_user 3 4,713 02-24-2026, 04:43 PM
Last Post: evilbunny
  TPM module for rockpro64 misha64 0 3,351 12-03-2024, 06:19 PM
Last Post: misha64
  ROCKPro64 Battery Power Supply hoarfrosty 12 12,752 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 3,877 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 46,325 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 3,591 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 6,007 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 15,768 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 4,216 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  Posible manufacturing problem with Premium Aluminum Casing. commiecam 0 3,383 09-09-2022, 10:47 AM
Last Post: commiecam
