Latest Android Build and associated kernel source
I have a Rock64 board and wanted to give it a try again.
I see new Android releases made for this but do not see git repos of kernel sources for the new release.
The last time I tried Android it was based on a 3.10 (? ) kernel. I think Rockchip has moved to 4.4 kernel.
Vasant
Yes it has:
rk3328_box:/ $ uname -a
Linux localhost 4.4.167 #1 SMP PREEMPT Thu Jul 25 13:04:48 MSK 2019 aarch64
Taken from Android TV 9 built from the repository described by dazza5000 here:
https://forum.pine64.org/showthread.php?tid=7711
Video
(08-15-2019, 10:15 AM)AlexS Wrote: Yes it has:
Very good, I will give it a try. Another question, Is the Android release rooted ?
Vasant
(08-20-2019, 10:42 AM)Vasant Wrote: Thanks
Vasant
Hmm, yes. It surprisingly appeared rooted after install.
My true trouble is that using Android9 i can't get addon DAC card working. It seems that system started to consume more power with Android9 and the power supply is not enough for it. It hangs periodically and DAC does not work (no sound from SPDIF interface). Had to get it off for better days.
Vasant
I will give this another try,  although my build machine is somewhat slow to build Android SDK.
Vasant
  Android Images (ROCK64) pineadmin 76 177,925 05-13-2024, 04:13 PM
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 7,110 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 6,134 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,597 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 5,016 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,342 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,822 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,600 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,811 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 5,145 09-18-2020, 07:58 PM
Last Post: BowerR64
