JMicron cipset SATA PCI-E card support
I would like to use this SATA expansion card
https://www.delock.de/produkte/G_89384/m...anguage=en
but before I want to know that the rockpro64 supports the JMicron chipset. I'm not a Linux expert, therefore I appreciate any advise / suggestion where can I find the related information.
Thank you.
(07-27-2019, 08:33 AM)Yroth Wrote: Hello,
Thank you.
My guess may not work.
It might work and each port is capable of 6gbs sata3 but all ports share a maximum of 500MB/s x2 for the x2 pcie 2.0 lanes.
With x10 drives that would be 100MB/s theoretical max per port and that is if it works.
I think its prob a pciex2 switch running 2x of there 5 port sata cards.
  AW-CM256SM wifi card mtek 4 2,363 10-30-2023, 12:00 PM
Last Post: diederik
  Which SATA card should I use my NAS server RAID5 Louysa 3 908 09-24-2023, 04:40 AM
Last Post: JPT223
  SATA keeps crashing JPT223 1 559 09-21-2023, 10:52 PM
  SATA hotplug not working? JPT223 0 438 09-15-2023, 04:20 AM
Last Post: JPT223
  Compatible PCIe Sata Controller spacebricker 1 1,574 02-06-2023, 10:03 AM
Last Post: diizzy
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 25,894 12-18-2022, 06:25 PM
Last Post: heyghoge
  PCIe bifurcation support (on RK3399) Arn 1 1,344 11-28-2022, 05:12 PM
  Support for Refresh rates Above 60 publiclewdness 0 1,271 01-01-2022, 11:40 PM
Last Post: publiclewdness
  Full Size Bracket for the NVME PCI-E Card publiclewdness 0 1,383 12-31-2021, 12:53 AM
  PCI-E X4 to M.2/NGFF NVMe SSD - support? AndyOfLinux 22 28,410 12-13-2021, 11:04 AM
Last Post: Cerberus
