Pinebook HDMI not working
I received my new Pinebook yesterday, newest model with 1920 x 1080 screen, all is awesome with the exception I am not able to get the HDMI output to work.  I have used 2 different monitors and get the same result, both show that a signal is present and switch to that input however neither will display any video or audio.  I have used the same cable with both monitors with my dlsr cameras as well as other devices and all works with other devices.  I am using KDE Neon as was preinstalled with all current updates and everything else is perfectly working otherwise.  Am I missing something?
Thank you Smile
(05-15-2019, 04:27 PM)DarkShadow Wrote: Hi,
Thank you Smile
What you're missing is a mainline OS image :Smile HDMI should work with Manjaro, Armbian, DietPi, AOSC and other mainline OS images. I don't think that anyone ever got HDMI to work with the BSP kernel.
Thank you Smile
Oh, was not aware of that, thanks so much will give this a try!
  pinebook 1080p power/barrel connector/cable cel 0 545 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,378 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,230 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,637 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,338 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,614 09-25-2021, 12:03 AM
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,622 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 13,814 12-19-2020, 06:55 PM
Last Post: ron_burgundy
  Pinebook doesn't charge anymore Reinoud 0 2,679 08-20-2020, 08:18 AM
Last Post: Reinoud
Information How To Setup Serial Console Cable Over the Pinebook MarkHaysHarris777 4 22,920 07-02-2020, 06:33 PM
